ENERGY AMPLIFICATION
0 Members and 54 Guests are viewing this topic.
totoalas
a spark gap from ignition coil plus earth on the  ferrite e core has increased the ac voltage from 120 to 345 v ac   using wall adaptor
in my test :)
Tito L. Oracion
Quote from: Farmhand on February 10, 2014, 04:45:41 AM
You didn't say anything that made any sense for me to say if you are right or wrong.  ??? ??? ??? ??? ??? ??? ??? ??? ???
I asked you a simple question and you talk in tongues.   :P :P :P :P :P :P :P :P But do not or cannot answer.
"You charge a capacitor to a very high voltage." I do that often, do you ?  ::) ::) ::) ::) ::) ::) ::) ::) ::) ::) ??? ??? ???
"Then amazing things will happen ?" Depends on what you mean by amazing.  ;) ;) ;) ;) ;) ;) ;)
How about you show us something you have built ? Or are you all talk ?  ;D :D ;D :) ;)
I'm not playing your games. If you cannot show us something that you have built then I say you are full of it, and simply playing games for attention.  :) ;) :D ;) :) ;D :D ;)
You don't need any attention from me, plenty of others will give it to you for free.  :) :) :) :) :) :) :) :) :) :) :D :D :D ;D ;D ;D :D :) ;) ;D ;D :D
:D ;D ;)
Free attention = free energy,  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;) ;) ;) ;) ;) :) :) :)
Cheers, Want more emoticons, here  >:( ;) :) ;) ;D :D :D :D :D :D :D :) :) :)
Have some more  :) ;) :D ;D :D ;) :)
Hang on I forgot one  :P
See anyone can post silly stuff, it's easy. How about answering the question.
Why should the circuit give up free energy ? Are you capable of giving a comprehensible answer ?
If you don't I will assume you are not.
Cheers
So you do charge caps into high voltage very often, hmmm, so what is the our difference.  ;D ;D ;D
I am not getting nor very interested in your attention!!! >:( >:( >:( :P
I'm just making video sharing here and just giving some tips and sometime asking question here for me to learn also. got that?
Now!, i think i don't have any obligation here to answer you what you want.
So weather you want to believe or not, I don't care!!! period! :P
one more thing, you try to learn how to use emo icons ha ;D  don replicate me i'm more worst! lol >:( :( ;D :D :D ;) :) :o 8) 8) 8)
@everyone
for the sake of everyone. you think about this:
Why tesla made a patent about power regulation?
obviously He has burned lots of components isn't it. ;D  what a genius Tesla. lol
Experience really is the best professor isn't it. :D ;D
The Farmer ;D
Bruce_TPU
Quote from: totoalas on February 10, 2014, 04:47:33 PM
in my test :)
Now that may be interesting.   And did the current diminish as the voltage increased?
Was it open circuited voltage or across a resistor?
a.king21
Quote from: forest on February 10, 2014, 08:55:50 AM
No Dave45. You got it right previously. Again back to Tom Bearden moving picture  ;)  Save it and analyze frames. That is the essence when simple Farmhand "activity" converts into magic Tesla ACTIVITY.
Forest:  Do you have a link?
Magluvin
Quote from: Grumage on February 10, 2014, 04:41:12 PM
Dear Bruce.
Non taken !!  :)
What I did not understand was the fact that a 1:1 ratio transformer created a non 1:1 ratio output. With a load attached as well !! Could you explain the reason for me please ??
Cheers Grum.
I agree Grum. ;)
That seems special enough. I was impressed. ;D
Im not sure that it constitutes a parametric, as from what Ive read, there is no center coil, just the 90deg difference in the 2 openings of the core. Ive messed with multi cores, but not 3 coils in a row as you have. You might get the same effect without the 90deg cores, just make them 0deg and should be the same.  Is there any space between the cores, or physically touching? The parametric Ive seen is 1 solid core with the 2 openings 90 deg from each other.
If you can, it would be good to get some readings on in and out power. ;)
Mags
