ENERGY AMPLIFICATION
0 Members and 85 Guests are viewing this topic.
Dave45
I found this circuit interesting, using electron current flow
When the transistor S2 is on current flows from neg through S2 through the diode D4 into L1
When the transistor S2 is off the bemf from L1 which is pos charges C2 on the pos side this in turn pulls from the neg terminal through the primary on TR.
The pos bemf is high voltage hitting C2 so this will pull harder on the neg than just pulsing the primary of TR using the transistor.
C2 receives a pos charge from the bemf as does the cap across S2
Interesting circuit, its what gave me the idea to pull neg charge from earth.
Google
Quote from: jbignes5 on April 12, 2014, 11:47:23 AM
Charge is not why voltage exists. Voltages exists because it is a balancing act that displacement of the medium creates potential or inward focusing or a pressure to the void of the medium. Thats why voltage exists. When there is no matter at all in the medium there is no potential difference in that medium. It is very uniform. Only when there is matter can the medium be divided and form pressure which causes a voltage potential between to points in that medium. But what is the medium then by that definition? The medium is a perfect form of matter with no charge whatsoever. It is undetectable because it conducts perfectly. It has zero force because it has zero charge. Ever wonder why we can see other galaxies with ease? Why we have a hard time seeing our own internal galaxy components? it is because the galaxies are filled with matter. It is imperfect and hence why it has so much radiations. In between galaxies is pure medium. So clear and perfect from the facts that we can see with clarity other galaxies with ease. Each galaxy is a bubble in this perfect medium. The bubble is created with expanded matter or charged matter. What gives matter charge is simply all the perfect medium pressing in on this matter bubble. Pressure is voltage potential in this case. The force pressing in is invisible but is made manifest by matter being acted on by this pressing force. So it is a loop. Once started that loop will go indefinitely without further input from anything. I'm not saying it doesn't shift and change but the sum will always equal the total force. If an area becomes quiet and less active another area becomes more active.
Now some premises are very correct that we view. Like the balancing actions. They will always equal the totality of all matter in the galaxie. Matter=displacement of the medium=Total energy available. Differences in potential based on matter and displaced medium are the reasons for flows to occur. Once flows are established magnetics comes into play from the flows.
So a voltage can exist without a charge ?  ;D ;D
The elementary charge, usually denoted as e, is the electric charge carried by a single proton, or equivalently, the negation of the electric charge carried by a single electron. This elementary charge is a fundamental physical constant.
Voltage is defined as the work done by a unit positive charge, carrying it from infinity to that point, while voltage diff between two points is the work done by the unit positive charge from one point to the other.
jbignes5
Quote from: Google on April 12, 2014, 12:12:07 PM
Voltage, electrical potential difference, electric tension or electric pressure (denoted ∆V) and measured in units of electric potential: volts, or joules per coulomb is the electric potential difference between two points, or the difference in electric potential energy of a unit charge transported between two points.[1] Voltage is equal to the work done per unit charge against a static electric field to move the charge between two points. A voltage may represent either a source of energy (electromotive force), or lost, used, or stored energy (potential drop). A voltmeter can be used to measure the voltage (or potential difference) between two points in a system; usually a common reference potential such as the ground of the system is used as one of the points. Voltage can be caused by static electric fields, by electric current through a magnetic field, by time-varying magnetic fields, or some combination of these three.
Of course leave out half of the explanation to serve your purpose.
a.king21
There's no point in theoretical discussion. They get you nowhere.
Let's stick to facts.
http://www.youtube.com/watch?v=Jr9JHegfymA
Google
Quote from: a.king21 on April 12, 2014, 12:37:00 PM
JB knows the better half of Voltage but wont tell openly.  ;D ;D ;D Thats JBs secret like Tito's secret. You wanna know whats in the black box ?  :D ;D ;D Start buttering JB.  :D  ;D ;D
The electrical universe.  ;D
