ENERGY AMPLIFICATION
0 Members and 154 Guests are viewing this topic.
Jeg
Quote from: Dave45 on April 13, 2014, 10:52:50 AM
This would explain the behavior of the TPU
I am trying to follow you but i have some difficulties. What is your consideration? I see coils in your design that separate the charges by themselves. Why you need the iron ring?
Google you are always two steps in front of us. You are like an alive wikipedia!  :D Can you combine all this info that you post inside here? Then i am sure that something good will occur. When i see asymmetric capacitors, lifter comes in to my mind, anti gravity and electrical imbalance which leads to one side pressure. Do you think that a capacitor like that can work as a diode at the same time?
stupify12
If you dont mind could you show me some example circuit on what you just describe. :-[
I am about to make plans for a Tesla coil which actually we know that design to produce HV HF circuit to ride on with 50 to 60hz. So that the resulting spark gap discharge on my Tesla Transmission will be a 50 to 60hz impulse or burst of condense energy. In that way I can easily extract the energy on the Output Coils with no more complicated frequency filter and other annoying circuits. Hehehe ;D ;D
@Jeg I know you understand very well what I was talking on this post.  Thanks very much for the info about the 50 to 60hz though I appreciate it! ::) ::)
Meow   8) 8)
Quote from: Jeg on April 13, 2014, 10:50:26 AM
Stupify.
I already described a way but perhaps you missed it. It works great though. If your primary is a mosfet, then supply it with a fullwave or halfwave rectified dc from mains with out smoothing capacitor. Then you create bursts of 100Hz or 50Hz containing the HF oscillations.
Dave45
Quote from: Jeg on April 13, 2014, 11:35:51 AM
The coils create ion clouds, if in close proximity the charges will recombine, like static eliminators, the ring keeps the charges separated then they can be collected.
Google
Quote from: Dave45 on April 13, 2014, 11:41:49 AM
Not so complex.  :o, you need to correct your direction. TPU has nothing to do with charge separation. Rest is your wish.  ;)
