ENERGY AMPLIFICATION
0 Members and 70 Guests are viewing this topic.
Jeg
Some thoughts for converting existing technology to low pressure systems. Simple and easy.. Every component 'feels' only potential difference. Doesn't matter if it is from 0-24v or from -1024v to -1000v
Bob Smith
totoalas
http://www.wholife2u.com/products/c-results
Has anybody tried this  and what results obtained
thanks
totoalas
John.K1
Just somethink to think about.
On my workbench you can see partial setup of Ufopolitic's  cold electricity cuircuit.  As you can see from the 24V battery I lit 220V -120W  halogen bulb at its 35-40% brightness while drawing between 0.5-1 A .
On the scope you can see small green signal from SG (10V)  and responds from the coil reaching 500V. Across that load my Vrms shows 36-40V.
Now the idea to think about. On the time base you can see the difference between rise -drop time between triggering signal and the coil response peeks. The theory says with the sharper characteristic of the signal you get more energy. So the question now is why not to use that sharp pulses (2-4microsec) from the coil and feed it to other coil to generate even more energy? Hmm?
Jan
DilJalaay
Quote from: John.K1 on April 28, 2014, 02:26:53 AM
Jan
Nice work Jan, its looking very nice Sharpe pulses. Can you give us your SG and these pulses frequency. Which FET you are using?
Here i am attaching what you are looking for(Special for you).
i.e: using these pulses, and yes more sharpe and more short pulses, we can get more power.
Regs,
D.J
P.S: I will appreciate if some one experience and practical guy tell us the the values of diodes, capacitors and coils... or some pictures of real PCM.
