ENERGY AMPLIFICATION
a.king21
Tito: so the analogy is high voltage into a lower voltage.  Right?
Tito L. Oracion
Quote from: a.king21 on May 25, 2015, 10:27:27 PM
Actually i'm just talking about bigger version then to rotate a generator using a continous flowing of water. :D
high voltage to low voltage is not always work in some cases, the secret is accumulation.  ;) 8) :)
Consider this: if you have a small flowing of water into a big tank, then using that big volume by a small fraction to create a big boom. ;) 8)
The small stone ice from  top of the hill that tesla tries to teach us is just actually an accumulation right buddy?, ;)
so long buddy, happy experimenting. hope you can get it everyone. ;)
but there is always a better way and automatic technique. :)
NOW THAT IS A VERY OBIUS TIP OKAY. EVERYTHING IS SAID ALREADY!
ALL YOU NEED NOW IS JUST THE ACTUAL THING HOW TO DO IT RIGHT, NOW THAT IS YOUR PART OK? ;) :)
;D >:(
Do you not understand that pumps like that only pump a _fraction_ of the water that is supplied? Look at the right side of the drawing, do you see the exhaust ports? Most of the water that comes in to such a pump is vented overboard at the level of the pump and only a small portion of the supplied water is actually pumped up to higher level.
Dave45
Quote from: Tito L. Oracion on May 24, 2015, 08:43:05 PM
That is actually a battery charger, a begenie circuit. :D
What really happens when a battery is being charge? ???
= it just reseparate the charge, making a sucking action of electrons from the positive side and forcing them go back in the negative side.
note : no power being used from the source in the secondary but force effect that makes separation. got it?.  ;) 8)
otoitits ;D
This key when working with a battery.
Take the boost convertor it just runs electrons from the neg to the pos if scaled up it moves electrons faster.
Bedini found it takes two battery's one to run the circuit and one on charge.
But Bedini's circuit uses a boost circuit to charge, a buck convertor may be better.
I think the best that can be accomplished is to extend the run time of the battery, with the right circuit.
One may look at battery charging circuits, then run the load on a separate circuit.
Dont hold me to this I just started looking into solar panels and solar chargers but I think the mppt charger uses a buck convertor to get maximum current to the battery's Im looking into this further.
dave
zdiblo
Quote from: Tito L. Oracion on May 26, 2015, 06:54:11 AM
I think we can get this accumulation with the right 3 coil setup...Tito can tell us more about how to coil it?  ;)
