ENERGY AMPLIFICATION
0 Members and 78 Guests are viewing this topic.
Dave45
Quote from: Dave45 on June 08, 2015, 04:56:34 PM
https://www.youtube.com/watch?v=zpkh7_Eyctw
How to separate 300,000 volts a mere inches apart  ;)
so what would happen if you wound a coil around the barrier and pulsed it, with this kind of high tension.
So is the air ionized on each side of the barrier
The barrier would also stop the ionized air from combining.
Notice the arc must go around the barrier, give it a path through the barrier.
A coil wound on the barrier
padova
Dave45
In our search for free energy we look for anomalies,
This is one
Charge Separation
Theory, this is not theory this is in your face fact, you can see it working here.
forest
Quote from: idegen on June 10, 2015, 05:31:12 PM
In theory, the theory of what good?
I do not understand what's the point of this.
Publish?
The theory can be proved what I described above can be measured.
Anyone can repeat, can understand.
Hopefully theory is in Clemente Figuera and Buforn patents.
Quote from: Dave45 on June 10, 2015, 08:05:16 AM
This is one
Charge Separation
You do realise that that "toroid barrier" is a disc of heavy clear insulating plastic, probably polycarbonate, with the edge protected by some plastic wire-sheath material, don't you? It's not a toroid at all.
If you look closely you can see the reflection of the white terminal standoffs in the surface of the clear plastic disc. There is no "anomaly" shown in that photograph or the video it came from, at all.
