ENERGY AMPLIFICATION
0 Members and 242 Guests are viewing this topic.
shylo
Nobody talks about what happens to the input A,B.
The motor is constantly spiking the supply because the interupter cuts it off from the supply. The windings of the motor have to get rid of their built up energy somewhere no?
The faster the make breaks ,the more spikes.
artv
forest
Imho capacitor should be connected to motor coils only for a very very short period of time. Series resonance is absurd! With high inductance big capacitor the frequency is very low so the transfer of energy is tiny. it is just enough to refurbish the voltage on capacitor.Tesla said it can vibrate for hours when disconnected, so only a little energy is lost in parallel resonant circuit. Here is the confirmation that output is not loaded at all.
sm0ky2
Quote from: webby1 on February 13, 2017, 11:34:25 AM
I agree that the Ozone piece,, that is the coil and parallel plates,, are just a demonstration of the use of the energy being manifested.
The motor and fan are multitasking however.
As the air is converted its resistance goes down,, blow the converted air out and the resistance between the plates goes back up allowing for a higher voltage to be placed upon the plates, so the fan helps :)
The motor acts as  the  source to charge the cap as well as the device that stops the current flow through the coil and the high voltage spike that hits the motor is partially reflected back into the cap.
The cap and coil are more of a pulse relationship and the cap does not need to be fully discharged either,, you could have several pulses before recharging the cap if so desired,, so the frequency of a pulse is what?
The frequency of the motor and the interrupter are logistical parts that are chosen to meet the needs of the output.
Think about the Ozone part only taking the output from the HV spike that happens when the current flow is interrupted.
The fan is just a blade attached to the shaft of the interuptor motor.
It was convenient to place it here. Yes it helps stabilize impedance between plates.
As well as move the separated anions and cations out into the room, before they anihilate each other.
All in all the fan reduces losses in the Ozone part.
The HV side of the circuit is not electrically connected to the oscillator circuit.
You can replace the Ozone maker with any of Tesla designs, the coil transmitter, or literally any of his devices. You don't need a secondary for the primary to oscillate.
The only thing the secondary does to the entire circuit is add a slight impedance in the form of
An inductive reactance through the secondary transformer windings.
An adjustment of the spacing between plates of the Ozone part, brings the secondary
Into resonance with the oscillator circuit.
Now, this was designed with the frequency in mind, so the Ozone plates are already spaced
appropriately. The only adjustment needed to get this working, was a variable resistance
through the interuptor motor to controls its' speed.
If you notice, the oscillator is exactly like any of his others. Except that here: an adjustable
Spark gap (threaded screw type) is replaced by the rotary interuptor.
Which is the primary function of the motor.
To spin the rotary spark gap interuptor
This is not a physical contact commutator like we use today.
It is a rotary spark gap. Gap distance remains constant, and the time variable
Is controlled by the RPM. This gives a consistent voltage, current, and frequency.
Voltage is controlled by the gap distance, just as before.
Current is controlled by the time the discharge points are within range to spark.
By necessity, the parallel Leyden jars have more capacitance than needed to provide
Constant current throughout the discharge.
If you scope the current through the discharge you notice it is a square wave
Vs the triangle wave presented by a stationary spark gap.
That's not important to our discussion, except to say that the current is consistent
During the "on time" of the primary winding.
As well as during the "off time" when the Leyden jars discharge.
Another important thing, which is discussed in the context, but not noticeable
In the drawing: the commutator in the motor is NOT a rotary disruptor but an actual
a/c commutator that drives the motor. Even though they both look the same in the drawing.
One is a commutator, one is a rotary spark gap.
These were generally part of the same device back in that day
Simply because you needed a motor to rotate the spark gap.
See image below
The parallel Leyden jars can be replaced by the capacitance of a Tesla coil
As shown in the second drawing in the patent. Also the motor that drives the inductance,
And the rotary interuptor can be simplified to a single coil pulse motor. As also shown.
All in all the primary oscillator circuit is an resonant LC tank.
Wherein: frequency = 1/ (sqrt) [LC]
L is the inductance of the motor and primary coil in series
C is the capacitance of the Leyden Jars or the parallel coil capacitance
   If a coil is used instead of the capacitors.
n/m the b.s. and theory people try to add into this.
Tesla told us exactly how this works.
It's as simple as his original oscillator, just uses more complex parts.
Think of the Ozone part as being an interchangeable component
Every one of his components needs an oscillator
The oscillator works with any of his components
Almost All of his patents are the same
Oscillator + component
Learn how to separate these in your mind.
The oscillator patent works as a stand alone oscillator
It's his 'driver circuit'
Once you learn these oscillators, everything you see Tesla connect
to a secondary winding - can be replicated with ease.
Here's an old rotary interuptor with motor attached
Grumage
Dear sm0ky2.
I have to disagree.
A " Spark gap " suggests high voltage, in Tesla's patent it's plainly a rotary switch, connecting/disconnecting the series/parallel L/C tank circuits.
Cheers Graham.
leonelogb
@ll
What does mean those words.
Ozone Patent.
Quote:
"If air be forced between the plates P during this discharge, the effectiveness of the apparatus is increased and ozone is generated in large quantities"...
Could be, that him is talking about a Motor-generator, that increased its effectiveness with load. And the Next:..
"Continued production of ozone in unlimited amount".
I just asking!
