ENERGY AMPLIFICATION
Magluvin
Doug
Very cool.  Does it require any alterations to the generator to accept the wood gas?
Its not really free, but it is an alternative to gas as prices climb.
Mags
Doug1
 The gas needs to be cooled down so it will consintrate and it needs to be scrubbed or cleaned through filtration before air is added to it for combustion. It is high in nitrogen so the filter process should be such that it will reduce that content as well before the ice.
  The straight tube style in the simple gasifier looses the ventura effect of the Imbert which is why the simple version takes so long to reach the fuel cracking temps and waste reduction.An upside down double "V" tappered to work as a screen will work better and provide twice the surface area for heat dissapation at the base of the reaction zone.It also gives ya a area to reintroduce some of the gasses back into the last part of the burn if it is not being used for something ells.Still trying to decide if it should include some of the condinsate from the fuel in the hopper as it dries out from the heat surounding the hopper. It's a lot of extra work but it worked well at Sloss Furnace to crack water into HHO and send into the system as another extra fuel.
Magluvin
Was thinking today of the water idea halfway presented by Tito.
Not on how it might work, but as to why he presented it.  Sorry teets, but this is the thought process that you have instilled.
I think that maybe it was a diversion.  From what?  That is what I was thinking about. ;]
What? My lil Tesla coil project?  hmmm. Na couldnt be.  Could it?
Was it my voltage doubler after the neon supply? hmm.  umm, was it the 2 turn primary? Na, dont think so.
Well, I do have something different than just a TC.   That was when a light went on in my mind.  ;D   Just a maybe.  ;)
Could that 1 turn at the top with the light bulb lit, could there be something there?
If the discharge caps get charged to a level that breaches the spark gap, then that energy that it took to charge the cap each time will always be the same, no matter what the load. So most likely measuring the input for changes when applying different or numerous loads, the input will always be the same.
Now, that lil 1 turn at the top.  In my setup, the secondary is open ended, meaning no connections at either end.  Yet that bulb lights when put anywhere on that secondary, just a bit brighter when closer to the primary.  So im going to do some tests in that area, to see what happens when I have multiple, what should we call them, Extra Coils, to see if adding more affects the others.  Titos past clues suggest that once things are setup, that the more coils the more energy out in total. Something like that.
I decided not to be deterred.  Im thinking the water works was a distraction.
He has switched the subject on me before, maybe from ideas I presented that come close to the real deal.  Dunno yet.  Its just what me thinks.  ;]
Another thing I was thinking about the setup is, what is going on with how the primary pulse travels the open ended secondary. Is it acting like a core of sorts? Can we tap off of it without affecting the other taps and get more power from the total?
I just got home and spit it out there to see what some may think on what I think here.
Just a hunch.  Maybe Titi has spilled some beans along the way and wants to clean them up before anyone sees.  Me thinks.
Mags
ramset
I have to say Mags,His actions aren't very humanitarian,
Most Creepy actually!
Somehow his idea of what a Godly man would do with such
Knowledge has grown into a VERY questionable position!
Deceit /lying would be an appropriate venue for  such a man .
Chet
Ps
Your idea on the other thread for a "Testing" apparatus!
Excellent! Could be a good OU tool,as well as Safety.
Thanks Grandma
Magluvin
Hey Chets
Yeah  It sucks. I liked Teets. But it has gotten weird.
Yep, the detectors should be a tool of need for electrical, hho(atomic level shizzy), etc.
Im looking into it now.  ;]
Mags
