ENERGY AMPLIFICATION
0 Members and 43 Guests are viewing this topic.
endlessoceans
Quote from: leonelogb on September 02, 2018, 02:15:06 PM
For the good of all mankind  ;D ;D ;D 8)
Eight times as great  :o  :o  :o
Do not quote what you yourself do not understand.
Yes 8 times as great as a normal transformer but this is NOT overunity.  Just like a bifilar coil is many times more effective than standard coil but is NOT overunity.
So instead of raving about your Hero Tito who is in fact a stupid man either outline clearly or shut up
endlessoceans
Quote from: leonelogb on September 04, 2018, 08:04:55 PM
Bob you are one the few hero who said the true.
Like patent 454,622 :D
He could feed the source of the primary  8) ... and the center of the bifilar coil connect it to ground or to the negative of the battery ... That way the transformer or  would be running forever hahaha ...
Patent 454622 you say?
Even within such patent all things are understandable.  Telsa was yes using normal HV wireless transfer.  No magic No voodoo but NOT overunity as you imply with comments of "running forever".    Running for a long time yes!!   Running with greater efficiency?  Yes.   NOT overunity
Telsa stated - - -
I would here state that by the terms "currents of high frequency and high potential" and similar expressions which I have used in this description I DO NOT MEAN , necessarily, currents in the USUAL ACCEPTANCE OF THE TERM but, generally speaking, electrical disturbances or effects such as would be produced in the secondary source by the action of the primary disturbance or electrical effect.
SO.....
this is much the same effect as Doctor stiffler wireless energy SEC.    Very interesting and novel phenomena but not COP greater 1
nelsonrochaa
Quote from: endlessoceans on September 04, 2018, 10:36:37 PM
Telsa stated - - -
SO.....
Energy can not be amplified, but the work made by a portion of energy could be optimized making more work  and use less energy
https://www.youtube.com/watch?v=I_eja4gmpcY&t=665s
https://youtu.be/Te7NcDY-afQ?t=35
Nelson Rocha
forest
Exactly. There is no ław forbidding the amount of work done. COP of 10 should be easy with properRhumkorf coil
marathonman
A standard generator would self sustain if not for the cogging effect (Lenz Law) of the rotor and the stator being pulled back into register when rotating. when at a steady state the current draw on the primaries are reduced to just the IR2 losses as the magnetic field will not except and more magnetic field per the amount of current. once the field is at maximum the current will flow past the coil as if it was a straight piece of wire replacing only the IR2 losses.
using a magnetic field to act upon another while reducing the draw to just the IR2 losses will allow a device to self sustain it's self and the load as long as the system are closed or looped. electricity is Aether pressure modalities thus every electric system from man is a pressure regulated system. when the output draws more current, the resistance on the output side drops and more current will flow thus returning more current to the exciting system creating a more intense field thus continues until the pressure equal to the amount of resistance is equalized.
a very, very small portion of the output is fed back to the excitors and this is done over time as the electric pressure is built up in the system until it is equalized.
this very scenario is what is happening in the Figuera device and many other self sustaining devices thus no name calling in the world can change these facts.
if the input of a device is reused or circulated throughout the exciting system reducing it's draw to just the IR2 losses a device can be made to self sustain whether a status quo person believes it or not. it is quite funny that our entire Universe is a perpetual machine yet there are many NON believers.
that is the key to such a device and each side being closed upon it's self.
Good day gentlemen.
regards,
Marathonman
