ENERGY AMPLIFICATION
0 Members and 71 Guests are viewing this topic.
Belfior
Quote from: Magluvin on September 15, 2018, 05:57:29 PM
Have not read the link yet till later tonight, but I really like where you are going with this.  ;)
Thanks for posting
Mags
This seems what Jack Noskills is doing with his coilcap. Secondary coil is the coilcap and it is open. DC pulses from L1 resonate that coilcap just fine.
Magluvin
Quote from: densama on September 15, 2018, 10:02:57 AM
The basic theory for this is Tom Bearden's "don't kill the dipole" as described in this article. Basic conclusion of that: the electric field comes for free. Potential (voltage) comes for free as long as you don't influence the charge carriers that create your dipole, your voltage source. In the analysed systems, they all excite two inductive loads in series. Gray excited both terminals of the load train in phase, while Puharich and Meyer did this out of phase. This explains why Gray most likely used bifilar wound coils. To understand the basic principle, it is perhaps best to think in the line I have been following towards the solution of this mistery, which is as follows.
When you resonate an open coil in full wave resonance, you get high voltage, zero current at the terminals, in phase. So there you have the basic connection to using the voltage source for free, but you have to figure out a way to do that without disturbing the charge carriers that give you the voltage source.
However, with a single coil, the current stays inside the coil, so you can't use that. So, when you split the coil into two, you get the current in the middle for free, provided you don't disturb your voltage source, your driving circuit. So normally, when you use the current, you will disturb the resonance, which will eventually also disturb your driving circuit (because it is somehow coupled with it), so you still have to provide current to keep the system in resonance and pay the price.
And here's the trick: the driving signal is delivered to the coil on top of a half rectified carrier wave, which is fed into the circuit trough a high pass filter. Because the carrier is half rectified, you basically "touch" the coils into one direction, so you don't get any HF in there.
That way, you get the current and the power, but the disturbances caused by using the power, cannot reach the driving circuit, because of the high pass filter! And then you finally got what you want. You can use your voltage source, without disturbing it, so then you don't have to pay the price.
Once you have that clear, you can also imagine that you can drive this principle much further. As long as you make sure you have a proper decoupling between driving circuitry and load circuitry, you can most likely get by without driving the load train into resonance after all. At this moment, this still has to be experimentally verified.
If you would want do go beyond what these three did, the final trick would be to drive two identical loads in opposite phase, so the whole system is perfectly in balance and in resonance.
http://www.energeticforum.com/water-fuel/6227-stan-meyers-secret-preventing-electrolysis-5.html#post108949
ok. I replied the other day that I liked this post. It gave me an idea that may be something, and it doesnt need the high pass filter suggested above....
Many know of how to use an AV plug diode setup. My tests with it lead me to believe something I have stated several times before. I used a circuit board from an older printer/scanner that would drive a long thin florescent tube in the scanner that produces about 1kv ac output to drive the tube. Now when we apply the lead of the AV plug to just a single lead of the circuits transformer secondary hv output, the av plug can charge a cap. My belief was, and still is, that within the HV secondary when it is open ended, that there are currents in the winding in order to decompress numbers of electrons from one end of the winding and compress them to the other end for each phase of operation in order to produce the positive and negative charges at the secondaries end leads. Some have disagreed with my assessment.
So how do we prove my theory?  Well the post I quoted above inspired just that.... So here we go, along with other possibilities
So first we need to have 2 hv secondaries. Now we take the 2 leads from the secondaries that would put them in series and connect them to a very low ohm, low inductance primary of another transformer. Like if the secondary of the florescent driver were center tapped, we separate the center tap to do as I just said. Now here we dont use the AV plug as I described above. We just leave the outer ends of the 2 series secondaries open and the only connection to the secondary winding is the very low numbered turn primary of the second transformer(of which would be a step up transformer). Now, the transformers hv secondary would be open ended and not be loaded. If there is a current within the open ended HV transformer of our florescent driver as I stated that I believe there is, then our second transformer will have these currents flowing in its primary thus inducing its secondary for output WITHOUT LOADING THE FLORESCENT DRIVER!!! ;)
Was thinkin on trying this with my bifi coil. I will induce the bifi coil into an open ended resonance with another coil that is driven with a sine signal at the resonant freq of the open ended bifi coil and at the series connection between the 2 windings of the bifi coil I would have my primary of my second transformer and see if we get output from its secondary. If we load the secondary output then the primary inductance will be very low and should not affect the resonance of the bifi much if any. If it does affect it some then we may have to adjust the drive coils freq to compensate. Now, if we do get output from our secondary of our second transformer, then this would prove that there are currents in the open ended bifi as I stated due to the compression and decompression of electrons from open end to open end of the bifi, AND we will have a circuit that should not affect the input circuit. Also, we will be taking advantage of the self resonance of the open ended bifi to have an increase in the so called sloshing of the electrons within the open ended bifi coil thus more currents into our second transformers very low ohm and very low impedance primary. No high pass filter needed as suggested in the quoted post above. ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;)
If the electrons are compressed from one end of the open ended bifi coil to produce the pos and neg charges at its open ends, then naturally there would be maximum current flow in the middle of the bifi winding in doing so. Of which should drive the primary of the second transformer. :o :o ;D ;D
This is what I will try here soon enough. This is an open source idea for anyone to try. ;)
Mags
densama
honestly ,,, i not have tito device replication my own. But, i just intuitively KNOW that tito ALWAYS said the truth at least he show THE path. Just collecting tito clue and translating to my own language is hard part for me. Yeahhh .. i know u will not believe me, but its very stimulating reading experience to know ALL people here, to separate the wheat from the chaff . to separate the truth and non truth... but i have great happiness to do just that.
Tito, Dave45, erfinder, Bobsmith, forest, totoalas, zdiblo, toto, brucetpu, weizisky, tinman, wattsup is always supporting to this forum and helping me to gather right information. Thank you buddy and others ( i can't mention all supporting member here) ; its just amazing just to join with u. Really ... especially  tito ... new world particle phisics jenius from pinoy.    :o
Belfior
Quote from: densama on September 19, 2018, 01:57:52 AM
The problem I have with Tito that he has the same MO as Zilano. Guy interested in OU, but does not have any answers. Then he goes to a forum and tells he has the answer. People keep asking him stuff and he gives stories and tales so people are kept interested. Then he mixes in links to videos that he has found interesting, GOD AND JESUS and tells he is leaving after every post.
1. He is posting videos on so many subjects and telling the answer is there. It seems his invention has all the technologies in the world!
2. Writing in CAPS and talking about GOD is a clear sign, that he needs meds and therapy
3. Threatning to leave means he feels guilty about his lies and this bothers him, but it also feels so good people are interested in him
So your intuition tells you something and mine tells me other things. Hopefully Tito comes back this week and tells us everything!
