ENERGY AMPLIFICATION
0 Members and 85 Guests are viewing this topic.
forest
I also think capacitance is the key to overunity.
F6FLT
Quote from: forest on October 14, 2018, 03:17:31 PM
There are as many possible keys as there are beliefs. Everyone has keys but none found the keyhole!
forest
Quote from: F6FLT on October 15, 2018, 08:50:31 AM
it's around it's around
densama
good spark from Sparks
The Tesla switch is basically allowing the current from one battery to charge another.  Now lets move it up a notch and replace your batteries with two capacitors.  The transformer load allows you to completely discharge the first capacitor and still charge the second.  The current is transformed into voltage with less current flow but who cares it is still being captured and doing some work in the meantime.  Your current is gonna run no matter which cap is being charged.  You will have ohmic losses or heat and will have to recharge your capacitors unless you want to get into fine tuning the conductor fields.  Voltage gain is power gain pure and simple.  You take 1volt and transform that into 10,000 volts you done good.  There's alot of one volts around not alot 10,000 volts around.  The faster you allow a magnetic field to collapse the higher the induced voltage.  Now you store this induced voltage in a capacitor and hit your next stage with a sharper pulse.  The induced voltage gets stored again on a capacitor.  Now you spike it again in another stage and store it.  Now you can go on and on until your first little spike is now a huge spike.  All starting from that first little spike.  It will obviously take alot of time for all this spiking and staging and all the rest but we are talking energy here not work.  Work is never conserved but energy is.
https://overunity.com/6123/joule-thief/1485/
Tito thorium idea ":
secret of the tpu!!!!!
A small kick is converted to a big kick that is by connecting a coil in a primary but not really using any current, but when theres a cut in the primary then the energy at the primary will be added to the connected coil in the primary, and that is the collapse energy. am i right sir 8)
its like increasing the collapse energy that nikola tesla has discovered, and that is the slight increase in the collapse ok. 8)
and from that we can make increase in the output!
https://overunity.com/6492/spikers/msg152431/#msg152431
forest
except that slight increase is COP 10
