ENERGY AMPLIFICATION
leonelogb
TITO, TITO, TITO.....YES OR NO  :-* :-* :-*  ;D  8)
Quote from: leonelogb on November 13, 2018, 10:21:57 AM
Thank so much you  ;D ;D ;D Tito L.  :o :o :o  8)
I CAN NOT PUT THE SCHEMATIC....WHY........  ::) ::) ::)   ;D ;D ;D ;D  8) 8) 8)
densama
use one no #10 and number #28  awg.
Primary = #28 gauge magnet wire
Secondary = #10 gauge insulated wire
The primary and secondary coils are wound in opposite directions CW & CCW.
Bob Honest Smith wrote :
The two secondaries strike me as L-C circuits (there's no capacitor in the diagram - the missing component?). The cross polarity enables them to fire 180 degrees out of phase. When the cap on one side discharges in the positive phase, the other secondary draws in charge from the aether, then the converse takes place. It strikes me as essentially a ping-pong type of circuit - not a closed system, but one that is open to ambient charge. The bifilar primary would prevent secondary reflection from the pickup coil. I suspect diodes might also be needed between the secondaries and primary.
http://www.energeticforum.com/renewable-energy/20627-daniel-mcfarland-cook-4.html
again ... when there's free current .... also exist ping pong circuit .... why Tito ??? ??? ::)
https://www.hallvworthington.com/
leonelogb
Primary = #28 gauge magnet wire bifilar(two primary)
then secondary in serial with one primary # 10
Then other secondary as collector
Quote from: densama on November 13, 2018, 11:41:36 PM
densama
Quote from: leonelogb on November 14, 2018, 05:04:24 AM
whaaaaat ? .... why you tell the truth leonelogb .... why ? :-*
where is endless mouth circuit ? ;)
your answer ... give standing wave to aether .. leonelogb  :)
there's silent here ... busy contructing the circuit and keep for himself
soooo ... selfish the people here that attack and insult Tito and Dave45  >:( >:(
Magluvin
Quote from: Tito L. Oracion on November 09, 2018, 03:40:59 AM
NEED  LOT OF ACTIVITY???
WELL THEN YOU HAVE TO ADD LOTS OF COILS TO SPIKE, AND CENTIPEDE TECH IS GOOD FOR THAT! 8)
EVERY CUT THERE'S THE SPIKE AND  IF YOU PUT TEN COILS THEN YOU HAVE TEN SPIKE AND YOU CAN PUT A LOT OF LEG AS I HAVE SAID AWHILE POST AGO. OKAY? 8)
IMAGINATION IS YOUR LIMITATION OK! :D
or
  make my triple ping pong tech, 1,2,3 batch of caps, first, pulse the first batch of caps to the first coils with secondary, then pulse the second batch of caps to coils with secondary then pulse the third batch of caps to the third coil with secondary  then return to first batch.
in this sense you are just making rotation of charge and discharge but making an energy at the secondary to separate or charge the battery. just play with that ok, they are truth!!! >:( [size=78%]   [/size]
[size=78%]
[/size]
;D
hey tito
So is there multiple primary coils and just 1 secondary?? Like are we to drive multiple primaries in succession into the single secondary? ???
Mags
