ENERGY AMPLIFICATION
0 Members and 43 Guests are viewing this topic.
bringdownthezog
Quote from: partzman on November 30, 2018, 10:27:10 AM
I have to disagree here.  Back when the MEG was first introduced, I talked with Bearden and members of his team as an interested replicator.  I found them quite knowledgeable and willing to discuss the device to a point, but due to patent applications at that time, certain info was not discussed.  Anyway, I proceeded to build a MEG like arrangement which did produce excess energy.
My device was based on a pair of AMCC-320 amorphous "C" cores, used MOV's for loads, and had a rather modest PM structure for core bias.  Removal of the PM structure did affect the gain of the device.
The secondaries were wound on the cores in a directional manner in that all layers were wound in the same direction with a single wire returning to the start position of the next layer.  This cuts the voltage stress in half between layers as compared to normal layer winding and was done to minimize breakdown in the secondaries due to the high resonant peak AC voltages.
Simultaneous input and output measurements were taken with a Voltech PM3000 3-phase power analyzer with the MEG device operating at ~30kHz.  Due to the MOV loads, the output voltage and current waveforms were highly non-linear and reactive.  The measurement of these waveforms was easily handled by the PM3000 which did indicate a COP>1.
I ran many tests with this MEG variant using various loads, etc, until the secondaries finally broke down and I never felt the need to rebuild it as I had the info I was seeking.  BTW, it was very difficult and time consuming to wind the secondaries.
Pm
This was in 1995ish ? My guess. The PM was opposing the flux or aligned with the flux ?
memoryman
Without evidence, faith is blind. Maybe YOU enjoy being blind; most don't. Having faith means you accept everything as presented and doing so leaves you open to use by fraudsters, conman, faith healers etc.
partzman
Quote from: bringdownthezog on November 30, 2018, 11:06:24 AM
Yes, somewhere around that time.
Regarding the PM flux in the cores, it was both opposing and aiding the primary/secondary flux dependent on the primary drive configurations and timing.  It was also found that the majority of the PM flux did not penetrate deeply into the amorphous cores as one might think but rather remained close to the inner surface the PMs were in contact with.
Pm
bringdownthezog
densama
uhhhh .... Titus quote: To become different make some difference. lol  ;D
i don't have faith to make difference .... unconsciously
then i ask ... How come it's so?
Matthew 21:22
Mark 11:24
PROF: CLASS DID YOU SEE GOD?
CLASS: NO SIR!
PROF: DID YOU TOUCH IT?
CLASS: NO SIR!
PROF: SEE THERE IS NO GOD!
TEETSLA: PROF DID YOU SEE YOUR BRAIN?
PROF: NO TEETS!
TEETSLA : DID YOU TOUCH IT PROF?
PROF: NO TEETS!!
TEETSLA: SEE CLASSMATE OUR PROFESSOR DOESN'T HAVE A BRAIN  LETS GO HOME!
so simply & tricky ......  little twist from dis-belief to .........
hard to explain
https://patents.google.com/patent/US577670A/en
uhhhh  >:(
