ENERGY AMPLIFICATION
0 Members and 23 Guests are viewing this topic.
AlienGrey
What are you on about 'Jesus' is a word invented to mean savoir by King James
to secure his grip on his power that was invented by the Romans .
Perhaps you thinking of the 'Elohim' the cap[tors of the Samaritans who
say they were 'sky people' there is literally tuns of evidence to this day
that this is so.
Your probably reading the personal stories of Joseph and
Sera when they left left the garden of Eden translates to garden of animals).
Or perhaps you mean Yashure or Yeshua but he didn't belong to any religious cult.
On the other hand, sabotaging and this thread makes you a a disruptive
TROLL !   :) :)
                                               How to treat theoretical defined terms and numbers !?
Force,Energy,Power
Here in internal combustion engine/electric drive comparison
When 136 ic hp are equivalent 12,5 KW electric motor
http://www.evalbum.com/motor
Gas engines are rated at their peak hp, electric motors are rated at their continuous hp. The peak hp of an electric motor is usually 8 to 10 times its continuous rating.
and instead a. railway car 100 to 140 ic hp George Constantinescu changed to 10 ic hp + torque converter/ amplifier
                 b. street car 45 hp to 10 hp + torque converter/amplifier
                  a "peoples car " or in German : VOLKSWAGEN
https://en.wikipedia.org/wiki/George_Constantinescu
http://www.rexresearch.com/constantinesco2/constantinesco.htm
http://www.rexresearch.com/constran/1constran.htm
His idea was to produce a low cost one hundred guinea "peoples' car'' which would travel 100 miles on one gallon of petrol at the most commonly used road speeds of 30 to 40 miles per hour.
George first successfully tested a Torque Converter in a car in May l 923, using an experimental model that had been built only for bench tests. He obtained an old Sheffield Simplex chassis and replaced the big 45 hp engine with a 10 hp "light car'' Singer engine, and built a platform on the chassis. This car was driven around the outskirts of London loaded with 10 people, including the inventor at the wheel, fig.  21, and later towed a lorry up a steep hill. As a further demonstration of the capabilities of the car, six inch wooden blocks were placed in front of the wheels. When the accelerator was depressed the car climbed over the blocks smoothly and without hesitation, to the astonishment of the bystanders. This test was merely to demonstrate the possibilities of the Torque Converter, because even a 10 hp engine was much larger than necessary for the production car envisaged.
                           http://www.rexresearch.com/constran/fig25.jpg
                                                     http://www.rexresearch.com/constran/fig26.jpg
Testing, development and manufacture was carried out at the former Malaxa Ironworks of Bucharest during the 1930s. Initially, successful tests were carried out with a 10 hp engine and converter mounted in a 10 tonne railcar. These results were very encouraging considering that similar cars in other countries were using 100 to 140 hp engines. The next stage was the establishment of production lines and special machine tools for the building of 30 tonne passenger railcars with 60 seats. These were propelled by two engines of 20 hp each mounted under the chassis. These railcars ran without trouble at about 40 mph, a performance which appeared to be quite suitable for conditions in Romania at the time. Looking to the future more power and faster speeds would be required on main lines as well as branch lines to meet the needs of rapidly growing industry and infrastructure in all countries. Bearing this in mind, George made a survey of requirements and solutions proposed in several other countries, including Germany, Britain and the United States.
                             how many rated KW need the electric motor coupled with the G.C. torque converter/amplifier ?
                                                       a.         ( 10 hp/136 hp) x 12,5 KW : ?
                                                       b.         ( 10 hp/ 45 hp) x 12,5 KW  : ?
                                            LESS THAN a. 1 KW ELECTRIC MOTOR and
                                                             b. 2,8 KW ELECTRIC MOTOR  !
        ( by pure calculation !)
                          The electric consume by high permanent magnets torque motor ?
An example : 2,8 KW nominal / 0,7 ( for 70% electro magnet motor efficiency) ~ 4 KWh consume per hour
4 KWh x 0,3 ( Ogino Sanshiro basic factor electric/permanent magnet motor 70% savings) ~ 1,2 KWh per hour
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=2002175580A1&KC=A1&FT=D&ND=3&date=20021128&DB=EPODOC&locale=en_EP
[0059] As a result of comparison between the structure according to the present invention and the structure as a comparison example comprising the electromagnet element 17 and the attraction member 57 without the provision of the permanent magnet element 19, it has been found that the electrical energy (W) required for the structure of the present invention is less than one-third through one-fourth of that which is required for the comparison example having no permanent magnet element 19 when the attractive force of each of the working surfaces is the same between the two.
[0060] Further, when we suppose a reluctance motor to which the structure of the above-described comparison example is applied, the energy conversion efficiency thereof will be about 30%. However, if a reluctance motor utilizing the structure of the present invention requires an electrical energy of less than 30% as compared to the structure of the comparison example, an output exceeding the electrical input can be estimated and this fact shows that the energy of the permanent magnet element is being converted into a dynamic energy corresponding thereto.
           https://www.youtube.com/watch?v=X58oEF1dBqg       https://web.archive.org/web/20090925065936/http://www.loremo.com/
When the Loremo concept car was calculated with a 20 hp ic engine ( eco version ),how many electric motor KWs will be need with G.C. torque converter coupling ?
When 45 hp ic engine was changed to 10 hp ic engine  then 20 hp would become changed to 4,5 hp ic engine !
       4,5 hp ic engine equates ? KW permanent magnet torque electric motor ?
     When we take the austinev.org comparison
    peak to peak 136 hp ic ~ 12,5 KW electric
     (4,5 hp /136 hp ) x 12,5 KW
      ~       0,42 KW Loremo electric drive + G.C. torque converter / amplifier
    When we see the Loremo we see the VW XL1 and the Amory Lovins HYPERCAR
                                                      https://youtu.be/ZiA4cpJb0uw
                                                            0:56  " ..... only 0,3% ..... "
             when 6 liter gasoline per 100 Kilometers  equates   60 000 Wh then represents 0,3% : 180 Wh per 100 Kilometers
             easy to renew the portable power storage during the drive : brake recuperation ,solar,......
    20 hp ic were from these " bestsellers" the engines their power : Morris Mini,2CV,Fiat 500
  Car drive energy renewable  source :
With 45% efficiency 1 sqm photo-thermo voltaic energy  conversion gives by full sunshine 600 Wh !
Reference : Sono- motor and Novasolix
https://pv-magazine-usa.com/2018/11/23/all-i-want-for-christmas-is-a-90-efficient-solar-panel/
              Force,Power,Energy : N.Tesla and Toribio Bellocq and George Constantinescu : sonic energy
In the 24/365 cities and their suburbs street and highways controled  future the "autonomous car,driver-free" does not need more rated power ,the G.Constantinescu car concept average street velocity equates nearly 100% the german traffic driver average velocity : 56 Km-h or 35 (land) miles per hour
His idea ( G.C.)was to produce a low cost one hundred guinea "peoples' car'' which would travel 100 miles on one gallon of petrol at the most commonly used road speeds of 30 to 40 miles per hour.
Average car velocity in german innercities :      +- 11 up to 14 miles per hour !
https://de.statista.com/statistik/daten/studie/994676/umfrage/innerstaedtische-durchschnittsgeschwindigkeit-im-autoverkehr-in-deutschen-staedten/
https://www.adac.de/_mmm/pdf/statistik_mobilitaet_in_deutschland_0111_46603.pdf
page 11  : 42,2 Km per hour car "fast" velocity ! 26,2 mph !
Probably taking an old "Lotus Elise" https://auto.howstuffworks.com/lotus-elise3.htm  ,
like Tesla Motor Inc. did : Lotus Elise chassis = Tesla Roadster chassis,
taking away the conventional engine parts and introduce the 5 KW permanent magnet motor and G.C. torque converter
Comparison : G.Constantinescu electric motor + torque converter with
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001020&CC=FR&NR=2792258A1&KC=A1
instead 50 hp engine         Porquer  differential + 4 x 500 W electric motors
                                        G.Constantinesu  (10/45) x 50 = 11,2 hp ic engine + torque converter
        (11,2/8) ic to electric = 1,4 KW electric motor + torque converter
BTW: Jesus has a plan ? Yes,clearly !
https://upload.wikimedia.org/wikipedia/commons/a/aa/Jorge_Jesus.jpg
After Flamengo de Rio de Janeiro he will be the new coach from Benfica Lisbon ! ::) ;) ;D
Both sites have :
https://upload.wikimedia.org/wikipedia/commons/thumb/8/87/Cristo_Redentor_-_Rio_de_Janeiro%2C_Brasil.jpg/1200px-Cristo_Redentor_-_Rio_de_Janeiro%2C_Brasil.jpg
https://lissabon.sehenswuerdigkeiten-online.de/sehenswuerdigkeiten/img/crisrei2m.jpg
Tito L. Oracion
Quote from: AlienGrey on July 21, 2020, 02:36:12 AM
that this is so.
TROLL !   :) :)
Hi sir, peace be with you. :(
Why are you calling me disruptive troll?.
Is that makes you happy? :(
You know what sir? If you can't see and feel God behind His creations, means you
Are totally blinded by the devil. No offence but that is the truth. :) :) :)
Proofs of existence of God.
I pray that God will open your eyes and mind. :)
https://youtu.be/eQVm8RokoBA
https://youtu.be/-iuGn9jSPmQ
https://youtu.be/dWrEczFaygk
https://youtu.be/ihnOkBC99RY
If these proofs didn't made you believe then
its so very sad. :( :( :( :( :(
I think i'm off the popcorn. :( :( :(
El or ELohim : and nobody,only I  ::) , writes and thinks about his wife Aschera ! :-\ :'(  I will abort EL from my heaven !  8)
        And will stay avec ELLE alone ! ::)
Tito,probably you heared about this european time era : https://en.wikipedia.org/wiki/Thirty_Years%27_War
                                               cuius regio,cuius religio
                            https://www.youtube.com/watch?v=VaG0-wPuanw
The base : the augustin mongue Martin Luther did translate the Bible ,from Latin into the ancient "german/saxonian" language !
http://www.zeno.org/Literatur/M/Luther,+Martin/Luther-Bibel+1545
Before this act the believer received "Gods speech" in "Latin"- language,a language which up to 99% from them did neither spoke nor  understood !
        believer an-alphabetism
                                 There-in was the MYSTIK ! The UNKNOWN ! The FANTASY !
But the churches their building ,with the sculptures,the smell from Myrrhe and incense,the images,the golden artefacts
                                               representing "heavens´richdom"
and the rituals from the "man in black (also called priest/reverend/pastor )"  or coloured during church celebrations influenced their thinking about the
                                                              "holly sea" and Paradise !
Now,in understandable language, they mostly felt violated,because for this they paid each year the 1/10 from their earnings !
For a childisch lend(a)/legende/saga/epos !
They become angry and for many the decision : anymore religio,but regio ! 1618-1648 p.C.
"Kommunistische Manifest" ,the political program from the "1.commun(it)e parisienne",written by F.Engels and K.Marx
and the french romano-catholic church their later answer ,for the "proletarier/worker "-movement defeat :
http://upload.wikimedia.org/wikipedia/commons/thumb/8/8a/Paris_Sacre_Coeur_BW_1.jpg/220px-Paris_Sacre_Coeur_BW_1.jpg
Do you know european language laws ,written and spoken ?
Angelo laws( today Danmark) ? Saxonian laws? Ancient and today !? Anglo-Saxonic ,angelo to anglais/englisch/inglais
GOD : is the G spelled or spoken ? Is the D an hard or a soft D ?             G´OSH = the voice       Górge = der Schlund
                                                    GOTT IS GOD ,fuer den Einen wichtig "existent zu sein", fuer den Anderen "Nihil"
                                                    GOTT in platt-german spoken  : Jott
                         IOS,Iove was the "God/Deius " in the roman imperium ,an italika conversion from the gracian ZEUS
                         latin an-alphabet logic  :P  : Io ve tudo/totum : Gott=Io + sieht= infinitiv videre/ver=sehen    alles !  God knows all
                                                        portuguese : Ceu = heaven
                         Deius now in portuguese Deus and in Fillip/Phillip-inic/spanisch/spanish/espagnol : Dios
                  In Psychology we think after S.Freud definition       I(CH)- Over-I - IT/ES(=GOD)                now in the Over-IT/ES state !
                 The Bible is also to find in the word Vibel/Fible/Fibel,ancient the basic school language learning book ! Bibliothek !
                 we are writing in latin letters and seldom in original language !
                 You are reading the Bible ? From right to left ? In hebrew ,the older part ,AT = Alte Testament ?
                 https://www.bibelgesellschaft.at/originaltext-bleibt-durch-uebersetzung-sichtbar
                 https://archive.org/details/dasneuetestamen04unkngoog NT = Neue Testament ?
stivep
Quote from: Tito L. Oracion on July 21, 2020, 06:20:54 AM
My dear friend .
I have looked  at  only this video and that was enough for me.
what the waste of my time.
https://en.wikipedia.org/wiki/Gerald_Schroeder
by assumption  of   Antony Flew, an academic philosopher
Gerald Lawrence Schroeder - Orthodox Jewish physicist, form MIT is
deist[9][10].
I'm Jewish too.
For a Human animal Gerald Lawrence Schroeder in his mind is not the cow and and not the dog
from the same group of mammals - the humans belong too
- and he is not even  some  special chosen human but  is just  human or simply human and there is nothing special  about him.
In wikipedia  he  is pictured as   making claims :  that
Quote" god's  6st  day  of creation  things    is  just ending now."
From that , it looks like God  was very much  like  Speedy Gonzales- to fast  for what it says about him in the bible .
So all of that fairy and furry biblical tales  doesn't match  with  Gerald Lawrence Schroeder  own teaching in
Hebrew University of Jerusalem
The biblical dragons and  all of the  god stories  doesn't match even to  explanation of  Schroeder  reality of time  frame.
I have nothing against any  creator or creators  before Big Bang.
I have nothing against you and your position in this area
go with it to another  social group please.
We were suppose to talk about energy amplification here .
Any Physicist  including Gerald Lawrence Schroeder must  obey duties  and requirements of the official science or become
an unconventional  weirdo ,  rejected by  world  and recognized by these who see benefit of keeping him there.
Physicist as every human animal must know that place to defecate in is likely  a toilet  in his privacy ....unless he wants to defecate at  others in public.
The primary role of  Physicist  is to deliver physical value and make theoretical , technological bases for technical progress.
Physicist  duty is NOT to promote spiritual values  - for that  they have  other guys all around
hungry for some  donations.
I'm happy that I'm American having freedom of expression written in constitution.
Dear Tito L. Oracion .
this is not synagogue  or church.
Participants of this forum  wants to "eat"  energy, equations, amplification, electronics and god is not giving us any direct
evidence  of his direct willingness to participate in human-animals  progress. - he is not writing   posts, here with technical data.
He or she  or it - doesn't want us
to have Free Energy..  given by   him directly...
QuoteScrew you human-animal..
do it yourself  using your physicists  if you want to ...
"U Ain't Gonna Get It"  from  me
Rules are simple. I request and you obey and I judge you based on my mood
or I'll send you and other mammals animals my latest creation - the corona virus.
Just because ...
because and because I said so.
___________________________
Yes even if Lucifer was mentally ill and not  able to  understand my greatness,
I created him this way and I  knew that he's gonna revolt as I know everything about  the future.
Even if Lucifer begs me to forgive him, as his only crime was blabbing to much in haven
I'll say NO..
QuoteI don't need  sin to disappear as this will make  humans all good..
Devils will become angles again.
No courts no crime
Church will get bankrupt
St Peter will be unemployed .
Nuns will start sexual life before they retire.
Somebody need to support them than.. Right
Nuns have very little time left Biological clock is running fast
You want to ruin  all of my system?
no saints not even ..old Irish saint will be mentioned  any longer
And who is going to bow  to me  as there is no more fear  of my  punishment.
And religion is spouse to be  based of fear..
Total anarchy..
I don't need this group of mammals  the human-animals to be happy..
suffering makes me great again.. and needed.
Sorry Lucifer,  I created you  with lower IQ  ,so  can  revolt  giving me an excuse to punish you for- asking to many questions.
No forgives for Lucifer,  as this is politically incorrect.
So now get your but, back to Hell and do your job I need you there .
Quotewhat kind of  frckin' reality  is that?
This was:
VERY MUCH CONTROVERSIAL  OPINION OF A SCIENTIST
Gerald_Schroeder is not gona give  you a sh*t
Be well Tito  , I wish you the best.
Wesley
