ENERGY AMPLIFICATION
Started by Tito L. Oracion, February 06, 2009, 01:45:08 AM
garrypm
From tito posting in another thread - is this what you guys are looking for ?
Hi buddy
base on my observation and experiment, in order for an electron or current to flow, then there should be an inbalance number of electrons from the two metals.
So therefore by making a pulse, then we are making an inbalance to something that is constant, and the faster pulse, then the strongest making of inbalance and the more powerful sucking effect of electron from the outside.
Magluvin
Another Titos tip....
figure 8 coil?
Why did you erase the post Teets?
Mags
Magluvin
I found this transformer from Qwerts book find, to be very interesting.   ;]    Good book
Mags
Magluvin
Was thinking on the transformer in my last post.  Normally, there isnt much transfer from 1 winding to the other in this configuration(without the cap).  But is there enough transfer to get the lc to ring, without affecting the primary adversely?
Then thought about how each windings(primary/secondary) fields act with the way they are wound.  The primary has a closed toroid core to work with, and the sec has a short open rod core(with a hole in it ;]) There may be some functional difference as to why the primary is toroidal and the sec is radial wound as shown.  If we try the other way around, maybe there is less transfer from the radial to the toroidal winding, and this is a good thing. ;]
I remember once that Teets said something about coils at right angles.
Its worth testing. 50khz isnt bad either. And im sure it can be made to operate at lower freq if need be.
Mags
