ENERGY AMPLIFICATION
Started by Tito L. Oracion, February 06, 2009, 01:45:08 AM
Dave45
You could say that electricity is moving through the ground back to the system but if we remove one load the other load still works.
Magluvin
Quote from: Dave45 on May 03, 2013, 01:04:55 AM
Actually there is a ground at the other end, like I show here in the transformer as a center tap of the 220 to get 110 on each leg. No? ??? :)
Mags
Magluvin
Sorry, forgot to post the pic above. Its there now.  ;D
Mags
Dave45
Yes there is a ground that comes in with the mains but its connected to the transformer case and to a grounding wire on the pole it doesnt connect to the transformer's coil.
The ice
say I have a nozzle (coil) and its spraying ping pong balls at a plate that is full of holes and I line it up perfect where all the balls are hitting the holes everything works great but as soon as I add resistance the balls start bouncing out, the holes are full they start reflecting.
but if I add a tube (ice tube) that connects the nozzle to the plate then add resistance the balls cannot reflect and are forced through the resistance.
Tito L. Oracion
