ENERGY AMPLIFICATION
Started by Tito L. Oracion, February 06, 2009, 01:45:08 AM
0 Members and 198 Guests are viewing this topic.
Tito L. Oracion
Quote from: stupify12 on September 18, 2013, 12:51:38 PM
Tol Otits, :)
          Peoples having problem reading ones great minds like yours ::) , I made this account to thank and congratulate you on solving the simple arrangement Tesla showed on his patents, and yet people take it for granted. I have also break the box that trap my ability to think, you showed me the way and your hint and clues  are really helpful. It is just a matter of ON and OFF, when ON - Parallel Resonance, when OFF - Series Resonance, Actually all people think the classical tank circuit they learn from books are Decaying Resonance once shorted to the primary all energy is wasted, Unlike Tesla's way every On and Off makes it Amplifying Resonance because of his Genius arrangement, that they never really understand what is the function of that High Self Induction coil doing there. There thoughts and mind are shrouded by the classical ideas from the books they learn. It is so simple that even a gradeschool can hit the switch on and off. The Resonance they learn from the books are not the same as Tesla's way of Amplifying Resonance. :o
Any suggestion of schematic or device that are interesting to dig out the so called free energy accumulator would be appreciated. Pinoy is the best when it comes to Historic Free Energy Devices. ;D ;D
Willingly yours,  :-*
Stupify ::)
Well, THanks for the appreciation and congratulation for what ever degree of info you've got, i'm very happy for you bro.
i want you also to discover the DC way of amplification cause ive'd found out that this is more safer than AC, well that is just my obsevation.  :)
it is really good to re examine others work to formulate a better one.  ;)
For me in my studies research and experience, the best or efficient way is not Ac nor DC BUT the combination of the two.  8)
by the highway, wag mong masyadong ibulgar ang ideya ok, para medyo mahirapan naman sila, iniinis ako nang mga yan e! ;)   :D   >:(   ;D
happy experimenting.  :D
always take care. ;)
lovingly yours otits  ;D
totoalas
Ate Helen aka Otit's
My new set up   no more grounding
Ssg  out  to ignition coil
Ignition coil output to 3 turns 4mm stranded  wire then in series with lamp starter then a another spARK GAP TO e core of primary
Secondary output vary from 12 to 1000 plus v a.c. when gap is adjusted
No load test  yet  need to make adjustable spark gap for better control
Dc and a.c. combo   i agree  Otits
Power consumption  1.3 amps       with spark gap
Lamp starter blue arc  very bright with spark gap
I'm using 4 x 6 mm e core   2 33000uf  63v dc and in4007 diode  and reed switch
stupify12
Tol Otits,
     You are right about  re examining other people who was the first to replicate Tesla. Im onto Carlos Benitez combination of DC and AC actually DC amplication . All I can say of all FREE ENERGY Devices are derived from the true master Nikola Tesla. The convension of this energy is so simple once you started the kick. All we need is a source of energy that never deplted and extract then convert. ;D ;D I already get everything not just small info, Im a learner my self and a obsess  maniac of Tesla's Works. the conversion are all cited on the Colorado Spring Notes, people think that we cant solve the AMPERAGE AMPLIFICATION, I think we Filipino should also focus on free energy devices like the Russian do because only this two kinds of people seems to solve the puzzle with ease. :o
Stupify.
Quote from: Tito L. Oracion on September 18, 2013, 10:54:22 PM
Bob Smith
OK. I'm on my way to bed, but this is bugging me, so I guess I might as well say it. What if Teets' device involved a series wound bifilar coil with a cap. What if a parallel wound bifilar coil was wound across the diameter of the swbf coil.  If you pulse the swbf, you will not have reflective losses on the parallel wound bifi coil.  So, wouldn't you get kick-kick, kick-kick, kick-kick etc.,....?  I need to sleep on this. If the arrangement is something similar to this, I suspect a diode is needed (Teets has mentioned this in the past). I just can't quite visualize how to discharge from one coil into the other, involving the cap.  I suspect the legs of the cap are across the 2 ends of the first coil, followed by a diode on one of the 2 wires, leading to the other coil's 2 (parallel) ends.  I know I haven't got it quite right, but perhaps I'm on to the basic principles, perhaps not in the right order.
Anyway, buenas noches a todos.
Hasta maƱana.
bob
Tito L. Oracion
well, we're all almost there.  :D
just a very small steps and voila success. :D
try your guts buddy, you can do it. ;)
The automatic successive kick started from the small kick is the way to be. ;)
JUST DO IT!!!  :)
IT SHOULD BE SMALL kick then it kick->KICK
                                                             KICK.  8)
SMILE KA DIN, KONTI LANG, BUKAS AKO NAMAN ANG TAYA. ;D
OTITS  ;D
