ENERGY AMPLIFICATION
Started by Tito L. Oracion, February 06, 2009, 01:45:08 AM
Bob Smith
Quote from: Tito L. Oracion on February 12, 2013, 12:57:09 AM
ok!
I just used the zener in my latest project which do not use transformer anymore, it has nothing to do with the our last project. clear?. :)
well, but if your asking if i used diode as a circuit controller, that's a big YES! and that is so easy and up to that only i cannot anymore give the detail ok?. ;)
Bob Smith
Quote from: Qwert on April 11, 2013, 04:06:44 PM
Here is the EDITABLE document I promised earlier, "The Super Tube" - chapter derived from the book "Quest for Zero Point Energy" by Moray B. King
I think this might be the pdf Teets was saying Qwert put together:
http://www.overunity.com/6763/energy-amplification/dlattach/attach/122488/
Bob Smith
Quote from: Tito L. Oracion on April 11, 2013, 04:03:50 AM
It's the radiant receiver of tesla and moray, Radiant energy transmitter and receiver is the perfection of alternating current. That is the climax of tesla in alternating current ok?! >:(
And i am really showing that way to all of you guys, go mad at me but that is the real way ok!  >:(
magnets are optional but really can amplify but if there is no magnet we can do it normally ok. no chemicals added!. :)
THINK ABOUT THIS, "WHEN TESLA PROPOSING THIS MAGNIFYING TRANSMITTER TO MORGAN, EVERYTHING STOPS THERE IN AC." DID YOU NOT NOTICE THAT? That is where the biggest suppression to tesla ok. stopping the support and destroying it.
Magnifying transmitter is the fulfilled dream of tesla ok. AND THE SECRET IS REALLY IN THE RECEIVER. RADIUM IS GOOD BUT IT WILL KILL ALL PERSON IN THE VICINITY EVEN YOU IF YOU ARE NOT INSULATED.
FULFILLED BECAUSE ITS ALREADY WORKING IN HIS MIND. DO YOU THINK TESLA WILL BUILD THAT AND SPEND LOTS OF MONEY JUST FOR NOTHING?
THINK, THINK, THINK LIKE TINKER BELL  ;D
NOW!, I ALWAYS SAY TO THIS!!! THAT IS THE REAL WAY OK. >:(
That thing circuit above is not a good idea ok.
well, it act like an equilibrium but its not a good one believe me  ;) low gain together again. ;D
JUST IMAGINE HOW TESLA VALUED THE CAPS.
YOU CAN NOW DO THE GUESS  ;D
Jeg
Quote from: John.K1 on May 02, 2014, 12:52:03 PM
Hi Jeg,
I agree with you, just charging in one way and discharging other way it is still about the same energy we putted from our battery. Our aim should be to charge that cap not from battery. To give it impulse, and let the nature to charge it (to get to the balance)
Cheers,
Jan
Jan and cadman you pointed out the same thing. Thanks! I saw it in practice, and i'd like to add a small detail which will make the difference between an OU and a conventional system.
Cap. bank needs a separate ground from the secondary coil. Voltage and Current in Ed's terminology, can not pass from the same line together in the same direction. If you force it to do it like grounding together the coil and the bank, then you make your ground useless, and what effect you will create, uses current and voltage from your battery ... (Cap bank sucks current from ground, while the coil sucks voltage..)
Would you like to discuss about ways to extract the energy from the bank without destroying the resonance? As Gyula said on another thread, when we put a low impedance load to the bank, disturbs the high impedance resonant circuit, and resonance is gone for a while until it builds up again. This meantime, in my test system is about one second and it is very annoying. One way that i am ready to test, is to put a diode and a charging coil right after the bank, driving a smaller capacity cap and discharging this small cap through a gap. But i don't have a good feeling as again during the recharging, a low impedance forms again at the output which probably is enough to destroy again the resonance.
wattsup
@Hi there guys
Hahahahaha
Back and forth, back and forth, this is the swinging motion of this thread.
I had been looking at zener diodes as well since many years I had been eluding to the usage of zener diode to actually be used as a pulsing medium. I have collected some nice zeners since then slowly but surely, but the one I really want to find I have not been able to find. Let's say you have a hefty sized 1 volts zener diode (10 amp). You supply it 12 volts, it will pass 11 volts. If that 11 volts can short the feed battery is some way, the voltage should then drop to zero volts, thus opening the zener, then closing it again with the next 12 volts application. If zeners can be used as the pulsing initiator this would be a great method for simple and robust pulsing. I will eventually have to work on that more full time to bring it to fruition. Time is always the factor.
About the cap charging in series and discharged in parallel, way back I made an animation of this on how I see this being accomplished with a solid state circuit of even with a mechanical switching method. All you need is to switch in and out with a radiant energy circuit feeding it and it should collect energy. I do not have the technical ability to bring this to life in a solid state way, but I am more then convinced such a circuit could be used anywhere to accumulate radiant energy from anywhere on the planet and make it usable, without considering this magic, hahaha. Or it could be a wind turned or water turned mechanical switching and as long as it turns, it accumulates energy without turning a drag producing rotary generator.
See here: http://purco.qc.ca/ftp/Wattsups%27%20stuff/voltage-grabber-circuit-VGC/
wattsup
