ENERGY AMPLIFICATION
Started by Tito L. Oracion, February 06, 2009, 01:45:08 AM
0 Members and 79 Guests are viewing this topic.
forest
Magluvin
Good path , good thinking. The essence is that small capacity we  can charge quickly with high voltage. Then make a switch like you wish and use another free feature ;-)
I wouldn't use that, too much hassle but in reality it will work just fine if you are good in making complex switch.
Benitez patent I can recall here . Let the power be with you.
Tito L. Oracion
Quote from: idegen on May 29, 2015, 06:41:58 PM
Basic studies ought to know.
Before you want to build the impossible.
It's hard on your head?
not have a energy amplifier !!!
It's a stupid theory!
Waste of time!
Sorry...it the truth
The power from electric industry is actually a free energy, the only thing why its not free because they are controlling it and making you to pay.
The style they are using is that they are depending on other free nature energy to produce electricity.
therefore it is not impossible, because its just depends on method or style or design or technique you are going to use on how to produce it.
and that's the big  troath! >:( :D :o
well, amplification is just a matter of coils and capacitors, BUT! without control its useless ;) 8)
like for example an avalantz, it is a big energy but its useless.
but if you can always makes an avalantz and can get enough energy to use  in that energy then that's amazing. ;) 8)
every time is not waste cause we can get experience to that. every time is learning even it is wasted. :)
just do it. even fail or success  ;) , i believe you will try another way or find another way. right? ;)
cause we learn from our mistake right?.
Now if you are always doing your mistake then something is wrong with you, you need to reconfigure. ;D
a matter of testing, looking, remembering, writing, discovering, backtracking, a little testing to yourself. will make you different thing from your previous you.  8) :o
no matter how it will take, you have to try it. ;)
always remember, be careful ok bro? ;) :)
Tesla done to produce easily into millions of horse power in almost instantly. see its not impossible. 8)  a matter of guts will do it everyone. :D
have you try tieng your hands with a big rubber bands in at least 20 sec and try to push your blood up before the rubber bands ?, when you remove the rubber bands, you will feel unexplainable feeling as your blood moving in your nerve toward your hand. see, just moving there is something happening in the tension you've made.  8)
and what is the meaning of that? ??? ??? ??? ??? ??? ?
it means we can do something or we can activate lot of things just by the movements of the electrons in the wire. 8) :P
and there are lots of electrons in the wire, believe me. right? :D :o
well, americium 241 can help. as moray says ion is the secret. right?
and very much available in the market. smoke alarm. 8) ;) ;D
beware of radiation!  ;D
otuts ;D
Bob Smith
Hi Teets
Interesting comment about the Americium.  Not absolutely necessary, but as an ionizing agent, I think it would help with the antenna portion. Then the rest is about collection, step up, step down and storage. But this is only one way, as I see it.
Hope you are well.
Bob
padova
Quote from: nelsonrochaa on May 29, 2015, 08:43:58 AM
...... We need to start by the floor not by the roof :)
Exactly so dear friend, when we build the house we must start from the ground, not other way around.
Tesla said something like that.  You can go from small to very large but you can't go from Very large to much larger.
Use tiny to get big.
Thanks again for your inspiring presentations. I hope your donators won't forget your work.
regards
nelsonrochaa
Quote from: padova on May 31, 2015, 02:25:30 PM
regards
Thanks for the compliment.
Yes it is very important to start things  with small and simple things , .
I know that my work is sometimes criticized on the grounds that I did not explain precisely that show, but people can not to forget that the "little" is that I share something, and yet it is for nothing just to that people can at least stop to inquire about certain phenomena in this area.
I do not usually receive donations only received two so far , and to do all this stuff and it takes €.
For this reason it will not be unreasonable to say that maybe I should not share face some less constructive criticism made by some people.
However I share.
Thanks again for greetings
