Simplest Solid State Tesla Switch!
Started by lanenal, February 10, 2009, 10:07:47 AM
BediniBattery
This is a completed circuit diagram showing all of the necessary components to build a 6 battery tesla switch.
There are 2 sets of 3 batteries which are switched from series to parallel.
The whole circuit is controlled entirely by a single 555 astable timer.
The 555 timer is powered off 12 volts dc, however the output must be increased to 30 volts peak to peak to switch the npn & pnp transistor on & off properly.
The transistors are used to either switch the mosfet gates directly or are being used to invert a signal so that it is the correct way around.
A 30 Volt 100ma Supply is required to switch all of the mosfets correctly using the BC546 & BC557 transistors.
