Possible unconventional overunity motor/generator?
Started by gravityblock, February 12, 2009, 07:20:05 PM
gravityblock
I'll try to give additional details on this design.
The layers that are wrapped vertically will be connected to an outside power source. When this layer is energized, then it will setup a strong electromagnet which the magnetic field of flux will cut through the second layer that is wrapped horizontally, and this second layer is connected to a motor. When you put a load on this motor, then the current will flow through the second layer to the motor, which will cause a change in the magnetic field of flux, which will create a permanent electromagnet in the first layer with no power source attached to it.
Do we need pictures for better clarification of this unconventional design?
I'm not saying this could work, I'm just throwing out ideas that may lead to something that would work.
gyulasun
Hi,
Yes some drawing would help better.
Thanks, Gyula
jadaro2600
If your electric field isn't changing, then use iron wire. aka, floral wire. This will help maintain a magnetic field since it's ferro magnetic and insulated.
z.monkey
Goodwill to All, for All is One!
gravityblock
Quote from: z.monkey on February 17, 2009, 11:27:38 AM
That sounds like a transformer to me...
I thought this setup may get rid of the back emf or maybe utilize the back emf to cause a change in flux that is not opposing the induced current (but it appears after more thought, the back emf will still be opposing the induced current), but is probably more like a transformer like you said.
I have another motor/generator idea but afraid to post it here for fear of being called a num nut (possibly is happening already). LOL. I won't give up posting my thoughts because even if my thinking is not right it could always lead to something that is correct or help me refine my ideas.
I'll post this other motor idea once I can draw a 3D pic of it. My 3D drawing is not good so don't hold your breath.
Thanks for your reply
