Knitel's InfinityPump
Started by wizkycho, February 16, 2009, 07:55:05 AM
hansvonlieven
@ wizkycho,
It does not matter how many of these abortions you latch together they will still do nothing.
For some reason you simply don't want to accept the realities of hydraulic systems and insist on silly postulates and even sillier arithmetic.
It is obvious you don't understand the first thing about physics and you have never built anything of that nature. If you had you would not be talking such nonsense.
Hans von Lieven
wizkycho
Quote from: hansvonlieven on February 26, 2009, 01:12:47 PM
@ wizkycho,
Hans von Lieven
@Hans von COE that just can't go further by any means
you again for second time make it personal so:
0. You just said that there is no such powerfull pump to pump a ballon !
1. There are systems that work in COE mode, but there are others that works in overCOE mode. it is prooven by now.
2. It is obvious You are not talking about Knitel's InfinityPump but trying to simplify or removing (on purpose or ignorance) parts of system that might make it work.
    It is irational way to approach any system.
3. Not one post I saw from you (not just here) has any constructivity or idea.
4. objects heavier then air can fly
5. find your imagination you could use it.
6. What about bringing Mlkovichs pendulum (that is by itself OU device) as pump in input pipe and get ridd of start pressure. OU pendulum would be driven with bouanycy
7. I'm establishing new rule, What ever childish rudeness You say in future bumps to you back with paradoxall multiplication. You could really use a lesson.
8. You are broken robot ? cause functionall one would still have logic.
9. Do not attenuate or turn off music when you come to the party !
10. You wouldn't be able to replicate even simplest working device ! because it would be overcreative to You.
11. Are You working on Your bouancy chapter ?
12. can you even change light bulb or is it too creative for you ?
hope those questions keeps you occupied
Wiz
have fun !
hansvonlieven
Go home little boy, but first wipe the snot off your nose.
Hans von Lieven
wizkycho
Quote from: hansvonlieven on February 27, 2009, 05:00:46 AM
Hans von Lieven
Since again You are personal
You haven't answered not one question ?
I give - You take
Aren't You just OverStupid ?
Wiz
wizkycho
@Hans
So you started to read about bouyancy and found out it just might work ?
now it is larger diameter (25 times) - weight needed of floater only 5kg - now is possible to construct floater in given space
negative pressure to overcome still only 500g/cm2
paradox multiplication is zeroed with pump that uses bouyant F=m*g from KIP2, it is gravity in reverse and since volume of floater can be now much bigger that force is
many times sufficient to continuously overcome 500g/cm2 pressure in input pipe !!!!!!!!!!!!
Knitel's InfinityPump now certanly works in Push-Pull mode  !!!!!
Wiz
