First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
georgemay
QuoteI also don't think that the 'pyramid energy' (if there really is one) has anything to do with conventional EM fields.
If this would be the case, they could be easily measured with conventional equipment.
Skywatcher,
Have you seen this patent?
http://www.rexresearch.com/grandics/grandics.htm
I hope you can call an oscilloscope as conventional equipment :)
As to releasing info about V12 I guess we have to leave it to Thomas, as I believe it is not an easy decision on his part.  I am happy enough that I have a pyramid to work with.  It is a lot of work ahead me but it is fun.  Those who started the project I strongly encourage you to continue testing even without v12 info.  Who knows we may come up with better pyramid?  :P
George
neptune
To CTG Labs. Did not mean to offend. What I meant was let us encourage those who are working on this,and let us not condemn it without a fair trial.Sorry....Neptune
vipond50
Hello Group
After reading the new postings i had a Q come to mind.
How many in the group have actually constructed a pyramid, with the converter?
If a few, Do any of u have any data to share, I posted what i have seen so far, Galvanic battery, even though, i see fluctuations to the readings when i relocate the converter or pyramid or both in relation to each other, I see a sweet spot "if u will "
The meter reading fluctuations are on the AC & DC side. The readings are in mV's, but still a reading?
So why am I seeing fluctuations in the readings by just rotating the Z axis?
Any others see this?
neptune
This post is in reply to those who sent me private messages. Please in future if you have questions for me post here. Thanks to tinu,Adrianu,Pese, Lofty, and alespr. I have not yet completed the V6 pyramid I am working on. Tinu, dont give up yet, we need guys like you. I expect you tried all the things I suggested the other day. New things to try will emerge daily on here, why not try outside, or at another house? If all else fails, set it aside for a while. Hopefully Thomas will be back.Lofty, Thomas`s Web site is closed at present.Ales pr, most of your questions and more would be answered by the diagram drawn byAcerzw, which I have, but don't have the skills to send it to you.Does anyone have a link for this? I believe the wire for the coils was 3mm[one wound clockwise and one anticlockwise.] 9 turns on each side. SALT water level determined by lower hole. Do not block holes.The3mm diameter graphite rods touch the sand. Fill entire tube structure with sand. The central capacitor has 5 pos plates and 5 neg. with air spacing.However I plan to use a plastic dielectric. I am NOT the expert. Just trying to help. Best to post future questions here. There are better brains here than mine. Happy experimenting everyone.
pese
Quote from: neptune on December 08, 2007, 03:41:45 PM
One Menber , have the totally forum saved on his hard-disk.
I hope he will copy some picts to OU , if TT cant or will not
more open his forum) We habe to thank him.
@Neptun
dont forget, gipsum (rigips)  (wall and plate). TT. say it is important.
Pese
