First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Earl
Quote from: Walter Hofmann on December 10, 2007, 04:41:13 PM
[snip]
any how what I am wondering is if there is allready a seperate group who did get via PM the plans because they dont show up here anymore ( ovidio and some others)
[snip]
greetings
walt
perhaps by private email, but not PM, since PM on this forum does not allow any attachments.
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Pontifex
It must be solution A as the confirmed step-by-step instruction says that the angle needs to be 90? degrees:
Greetz, Pontifex
Pegasus
Quote from: Earl on December 11, 2007, 10:43:28 AM
[snip]
[snip]
greetings
walt
maybe..... ;D
magpower
Thanks Pontifex
Will do
I burned off the wood from my pencil and cut one too 90mm and the other 95mm. They are 5mm wide and about 2mm thick, not perfect. I took a ohm meter and got approx 20 ohms from end to end. I assume using 2mm rod this would be less but will try this first.
Pegasus
I have conducted  an experiment to see if something happen.
Half glass cup was filled with quartzsand and exposed to the focus of the pyramid for a couple of days.Than I put in the glass some tapwater to make the sand just wet.I inserted the two  graphite electrodes and I connected my meter on voltage reading.The meter jumped at the end of the scale!.But was less 2 Volts....The test was reapeated some time later but this time the meter showd few mV at every reading.Again,after some time the reading turned to zero and not resuscitated..... Is it a real proof od something?.(The wet sand not exposed to the pyramid dont show any voltage.)
Regards,
Cyrano
