First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Pirate88179
@ 2toxic4u:
I have said it over in the earth battery topic and I will say it again here.....I believe that a lot of topics on here are all tied together in some way we do not yet understand....Dr. Stiffler's resonant circuit, the earth batteries, The tpu and the pyramid experiments....all of them as well as a few others. I believe that we are all working toward the same goal and that, the different paths lead to a single destination.  I also believe, from my reading, that the pyramid is a "lens" of somekind that will "focus" energy.  What energy?  Where does it come from?  Who knows but I really enjoy the attitudes and enthusiasm of the posters on this forum.  If anyone can find out the answers, it will be someone, or some people on here.
Tigrotto
Hi Cyrano,
Here are a short form  checking list on what you really did with your " magic quartz battery".
If you'll take two minutes in answering these questions, I'll have a good starting point in replicating and going ahead in understanding what really happens inside of pyramid.
As I told you, i'm Phys.Dr. and I understand something but...not all.
The list is this:
1. Your little Pyramyd is oriented N-S as that of Thomas? What kind of orientation did you tried in your experiment?
2. Did you do these experiment intoyour room, on balcony or in garden, out of walls?
3. 24 hours quartzsand treatment inside the pyramid: in a non-conductive glass recipe ?
4. The center of the glass where did you positioned inside the pyramid?
5. What kind of quartz?
6. Excuse my english: what means EXACTLY tapwater: saltwater ???
7. What is the distance between the two graphyte rods? How many millimeters?
8. The Graphyte(90mm)- Graphyte(95mm) -quartzsand - tapwater experiment: What  voltage did you get? For how long?
9. The metallic two electrodes experiment : What is the distance between them? How deeply did you insert them into sand ? What was the voltage, for how long?
10. Important: OK simmetry , but... did you oriented the axis of the two electrodes on N-S direction ?
11. The last one: did you meansed electrical resistance between your two metallic electrodes when inserted in sand?
Thanks,
And I promissed you that if you'll give me all the replays I'll try to give you a possible explanations (If possible!)
Dr. Ovidiu
Walter Hofmann
Hi cyrano,
my mistake I got it now and I will try this too lets see what's coming out at my side.
greetings
walt
Quote from: Pegasus on December 15, 2007, 09:16:18 AM
@Walter,
I made my experiment simply putting some quartz sand in a glass cup,and exposing it to the "energy"of.the center of the pyramid.The pyramid used is made by aluminium pipes,it is in scale with the great pyramid of Giza,and has no walls,just the skeleton of the shape.Also it is little;its heigth is less 20 centimeters.
After 24 hours I take the  vessel out of the pyramid,and I add some tapwater to just wet the sand.I add the two electrodes of graphite(with different length) and I measure voltage.I take the measurements outside the pyramid,not inside.There is no copper in the vessel,only two graphite rods,quartzsand,and some tapwater;its clear?.If I remove the electrodes and I insert the probes of the voltmeter,DIRECTLY in the wet sand exposed to the pyramid,I got voltage.This phenomenon  resemble piezoelectricty,but I'm not sure,because I havent take measurements with the same sand -not- wetted.In these experiments .If I use sand not exposed to the energy of the pyramid,I get pratically NOTHING,no voltage, in every mentioned cases.
I have to add that the "battery" created, get fast polarization,but if I leave it undisturbed for some minutes,the voltage returns to its original level.I noticed that after the exposition,I can take positive measurements from the wet quartz,for about two days,and then the phenomenon stops.The voltage I got is less 2 Volts.I will send some pics of my experiments,and if I have time I will send also the wav of the possible vibration coming from the quartz exposed to the pyramid energy.I will get it conecting the voltage of the quartz to some amplifier.
Now I ask to people that have the possibility to repeat the experiment into their pyramids,made of aluminium or not,to see if they get some results.It is higly appreciated that some people with academic knowledge will give me an explanation of the phenomenon.If it is piezoelectricity,were is the source of the mechanical excitation of the quartz?My voice,the noise around me?NO, because I tried the same experiments with the sand NOT exposed to the energy of the pyramid,and it -doesnt- work.
I HOPE IT IS CLEAR NOW.
Regards,
Cyrano
Gustav22
Hi Cyrano,
I also have a question regarding your experiment.
When you use the pyramid-treated quartz sand and you measure a voltage accross the two graphite rods:
Does the longer rod always have  the pos. potential (and the shorter rod always the neg. potential)
or is it always the other way round
or does this change (i.e the long rod has sometimes pos. and sometimes neg. potential)
Thanks
money for rope
Pegasus
@Tigrotto
Here follow my answers to your questions:
1) Yes my pyramid is oriented with North-South poles like the Thomas one.
2) I made this experiment inside a room near window,sitting the pyramid on the marble.
3) The containeir is a pyrex becker.
4) The focus of the pyramid act also on the sand trougth the glass vessel..
5) The quartz I use come from an aquarium shop.Its white and has a granulation of 04/08,the same requested by Thomas.
6) As tapwater  I mean the water taken from the faucet of my home.It contain some chlorine and its conductive,of course.
7) The distance is not important;it work always.
8)The voltage I got is less 2 volts.I cannot say the exact numbers because my analog multimeter dont show it.I'm whaiting a new      professional digital model. The time of duration is about 30 seconds.Seems the quartz is acting like when you discharge a capacitor.
9) As electrodes in my description I always mean the graphite rods.As metallic there are only the probe pointers,when I insert it.
Dont worry about the distance,deepnes,etc.:you will always get voltage
10) The axis of the electrodes are not oriented.
11) Yes there is electrucal resistance between the two electrodes immersed in the sand.
My explanation is:The source of excitation of the quartz is radiant enegy as Tesla called it.I'm familiar with these things so I not conducted the experiment deeply,because I'm not interested and I have little time.My goal is to get many many amperes.The keys of the multiplication of the energy are others.I want to suggest to put crushed limestone with the sand quartz and put it inside the pyramid and measure the power.One key is to compress the energy.
Regards,
Cyrano
