First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Hi MT
no the copper was not even corroded or discolored and I used a gun brush and run it thru before new assembling and I could still not find out why it doesnt work I did put it aside for later now I will finish the new one.
greetings
walt
Quote from: MT on December 19, 2007, 06:21:41 PM
Hi guys,
thanks a lot for your contributions. Sorry to see Tigorotto discouraged and TT not keeping his word for the second time. Maybe they "convince" him somehow its better to not to keep his word  :(
Anyway since yesterday I'm back in business. 2 hours ago just finished my frame (using screws). It is labor intensive I better weld it but then it would not fit into car. Tomorrow plan to place in pyramid frame small galvanic cell made from piece of copper tube with quartz sand, graphite and salt water similar to setup with U-shape tubing to see whats happen.
@Walter: strange you could not reuse old copper frame to get voltage fluctuations. Salt eated copper at the surface? Hm. Curious whether new fresh piping help and you can replicate the effect.
all the best,
MT
neptune
One thing I keep thinking is this. If after lots of effort we fail to duplicate TT s results, if we can find some strange effect that only happens inside the pyramid, we have a basis for further research. Much research has taken place in Russia. The Russians seem to favour fibreglass pyramids with no metal frame, and a tall narrow shape. Two effects are claimed which it might be possible to duplicate.
1 It is claimed that water inside a bottle at the focus does not freeze even at temperatures as low as minus 40. If it is then knocked or disturbed it will start to freeze.
2 It is claimed that a pyramid causes a vertical column above th apex that is visible on radar. Does any one know a the owner of a boat fitted with radar?
Other effects are claimed, but I feel these tend to be subjective and difficult to prove.
Keep up the good work.....
neptune
Some thoughts on non working V6 replicas. First, check all the thingsTT suggests. To me the obvious test load would be a lamp. This would have made more sense on a video because it would show visible results. Instead, a computer fan is used. I don't know much about these, but i assume a standard brush type DC motor is used . Could this have some effect on the pyramid converter,[back EMF etc].
            Two new ideas,
! try to "jump-start" the pyramid, by briefly applying 12volts from a battery across the output.
2 use a much higher resistance load[ 1 megohm or more] and apply a high voltage from some kind of static electricity generator to the output,observing polarity if possible.
These ideas may be rubbish but who can say without trying?
georgemay
Funny thing happen with my pyramid.  My collector had 0.57VDC across center capacitor before I hang it inside the pyramid.  After I hang it within 10 min voltage dropped to 0.48VDC. When I connected long capacitor and grounded with frame after one hour voltage came to 0.00VDC.  This morning on the output all I have is 0.002 - 0.001 fluctuating.    There is no short anywhere.  Is it possible to hook it up   backwards?
Remember also my replication differ a lot from planned.  Pyramid is only 3ft in size, I used pencil rods, capacitor is made out of bronze sheet and has 1mm clear plastic between the plates.
However my goal is not getting 6V either.  I would be happy if I get 0.7VDC - a little higher than prior putting it into the pyramid.
Anyone had similar experience?
George
Tigrotto
@all,
I just said to you :
It miss something. And Thomas intentionatelly didn't say all about V6.
The reason is this : Many of us ( including me tried unsuccessfully V6) .None obtained more than 0.5V!
We replicated successfully what TT said it is V6, but not the whole V6.
I'm one of you followed step by step V6 description. Nothing to do!
He'll never return here and I'm sure on this .
The story ended prior to start !
Cheers,
tigrotto
