First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Hi bill,
no it is 254mV, this DVM is the kind of automatic it switches over to the next higher seting automaticaly
greetings
walt
Quote from: Pirate88179 on December 27, 2007, 07:03:30 PM
@ Walter:
Was your meter set to read in volts?  254 vdc????? Incredible.!!
@ Jeanna:
Baby, you are a genius!!!!  The trick was in SAYING it was a trick.  You would make a good private investigator.
jeanna
Quote from: Walter Hofmann on December 27, 2007, 06:47:14 PM
Hi all,
here is a short video for all the courious guys in regards to what happens if a magnet is put close to the converter.
because the converter with the two coils on the vertical pipes gave no room to put the magnet right on this part I thoughd just put it on the vertical pipe because a magnet would stick to it and look the results
just amazing.
greetings
walt
OMG!
wow. Is that volts?
Oh I see your answer to Pirate. mv
jeanna
Walter Hofmann
Hi gustav22,
thats correct
greetingsa
walt
Quote from: Gustav22 on December 27, 2007, 06:47:13 AM
Hi Walter,
thank you very much for the efforts you make and for reporting your results.
Did I understand your setup correctly:
1.) As I understand you have connected each carbon/graphite rod  to its coil. Then you have connected the ends of both coils to the SAME plate of the central cap. This goes to the plus of your DMM (digital multi meter).
Please confirm.
2.) The other plate of the central cap is connected to the pyramid steel frame. This goes to the neg. of your DMM.
Please confirm.
3.) The copper tubing of the pickup.
Is it completely isolated from all other components or is it connected to one side of the central cap?
Please confirm.
4.) Your converter is located at a height of 225 mm between your cardboard base plate and the center point of the cap.
Please confirm.
Sorry.
I am aware that all of this has been asked before, but I find no concise description of your current setup, which seems the best setup anyone has come up with so far.
Thanks again.
edit: the above description was wrong. Walter has confirmed the following setup:
1.) Each carbon/graphite rod  is connected to its coil. Then the lower end of the left coil is connected to front plate of the central cap. The lower end of the right coil is connected to the other face plate of the central cap. The left coil goes to the plus of  the DVM (digital volt meter).
2.) The copper tubing of the pickup is floating (i.e. it has no electrical connection to anything).
3.) The neg. of the DVM is connected to the steel frame of the pyramid.
4.) The converter is located at a height of 200 mm between cardboard base plate and the center point of the central cap.
neptune
@ Walt, congrats on your magnet results, and also to Jeanna for his input. I am not in a position to do much with my set-up at the moment because work is megga busy and the wife's brother is in hospital 70 miles away and we have to visit him. it has occurred to me that although walt`s results are impressive, the odds against him having achieved the optimum magnetic field in the right place are very small. therefore more experiments are needed here. One possibility is to use the magnets from the magnetron of a microwave oven. These are toroid shaped, [circular with a hole]. What I shall try is to place one on each side of the copper frame above my coils. |One north pole up, and one south pole up. Then I shall reverse each magnet and compare results. I f anyone who has a converter with removable top piece beats me to it., that is OK by me A stronger field could be achieved by using 2 magnets each side, one above the coil and one below. This one experiment has given me much enthusiasm to continue .
jeanna
Quote from: neptune on December 28, 2007, 10:52:37 AM
These sound like good suggestions to me.
I won't have access to any welding equipment until the end of january and I am a beginner so it will take me longer. So, I just want to share another idea that I cannot try.
In the 60's and 70's Patrick Flanagan did many seminal experiments on the pyramid. In one of his conclusions, he says that the magnetic field is very important to the working of the pyramid. And he showed that by directing a magnetic field toward the pyramid perpendicular to any base in any orientation and getting the better results. He was not checking for electrical power but since this working model is here ready to tap the something I would love to see what happens if the a magnet is directed toward the pyramid FROM THE OUTSIDE.
Just another idea on my wish list. It will be a while before I can try it.
This is so exciting!!!
jeanna
