First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
PYRAman
I think I understood how the egyptian pyramids worked.
So, you know that pyramids dehydrate bodies, so what if they produce HEAT from inside ?
Now, by studying different sections of the old pyramids, I noticed that all of them had wells deep underground, where from they must have extracting water, in times when the desert was fertile land and water level was near the earth surface. By some means they conducted the water through the corridors and passages, thus reaching even the queens and kings chamber. I remember I read somewhere that when they first opened the great pyramid, they found salt on the walls, the walls being also a little erroded by salt. So, here we have the salted water of Trawoeger.
I think that Trawogers pyramid produces primarily heat, and when the copper frame is heated, some peltier effect comes into play, because there are more different metalls built into the frame. Then he collects the high current-low voltage and converts them by means of spool and condensers. You notice that the coil is not made directly on the copper pipe, maybe because the pipe gets hot?
Also, when you look to his old pictures, on the first site of this thread, you see the open hole of a narrower copper pipe, attached to the main copper frame. Maybe he added salted water in order to TUNE the copper frame to the frequency of the pyramid. I dont know if the V6 has something right in it, so we could start by making the frame shown in his picture.
I also have to say something else. After I understood how the pyramid works, I wanted to keep it for myself and make a lot of money with it, but as I rejoyed at that idea, something strange happened, in my head I heard a very loud and penetrating thought saying DONT BE SELFISH! That gave me the chills and kind of scared me because of its strength, that was definitely NOT my thought, so I decided to register here and tell the solution to you all. I will build my own pyramid and try it, but some of you have already built pyramids, so you can try it first.
PYRAman
neptune
@PYRAman. Whilst not wishing to totally discount your theories, i think the heat idea is unlikely. If the pyramid caused a significant temperature rise, I think someone would have already noticed this. Also the effect could be tested without a pyramid, by just heating the converter. If this device could provide 15 watts output with a hardly noticeable temperature rise, it would be very useful in other applications. Nevertheless, I am always interested in your views.
fritz
Theory of Operation...
I?ve seen a circuit used as detector for scalar/torsion waves.
You use a permanent magnet inside a faraday shield which
is exposed to a coil with one open end, tuneable cap to select
the proper frequency.
The theory behind this setup is that the scalar/torsion waves alter
the field of the permanent magnet which is causing a time variant
magnetic flux in the coil - which stimulates the energy transfer between
the open coil and the cap.
This is as far I am thinking about the closest match to what I?ve seen
on the video to v4 converter.
An open point is how the AC is rectified - but this can be due to the
materials used.
In such a case the pyramide construction would act as a directional
lens which concentrates scalar/torsion waves.
neptune
@fritz, I was very interested in your post, What was your source for this information? Is there any possibility of a diagram or circuit diagram? This could be the key to unlocking the mystery.
@all. Notice the discussion going on in the other forum about different types of graphite/carbon rods. Is this one of the keys to higher output?
fritz
@neptune
Mr. Bearden has it: http://www.cheniere.org/books/starwarsnow/scalardetector.htm
Its not too identical - but it "feels" the same.
...rgds
