First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Drannom
Quote from: Thomas_Trawoeger on November 17, 2007, 03:06:38 PM
@tigrotto: The Accu-loader was the Mother of my invention :-)
greets, Tom
in fact nobody up to now have found what is exactly an accu-laoder
it is a good clue to start investigation.....
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
nitinnun
i just realized!
thomas trawoger, only intended to make ONE counter-clockwise wire coil!
thomas trawoger had one long wire.
he soldered one end to that capacitor at the bottom.
he wrapped the wire counter-clockwise, around the copper pipe.
then he did the rest of the blah with it, and likely left it electrically sepperate, from the copper pipe.
he found that had excess wire. so he wrapped the excess wire, into a second counter-clockwise coil.
this second counter-clockwise coil, might as well be an extension of the first counter-clockwise coil !
so this ONE counter-clockwise coil, functions exactly like the ONE counter-clockwise coil, in les browns pyramid!
the counter-clockwise coil catches "electrons", generated by the pyramid.
electrons spin counter-clockwise. so a counter-clockwise coil, is capable of catching them!
by the way. the reason why copper pipe worked best for him, is because it had so many copper atoms, with which to generate "energy".
just like my glue cells produce more amperage, the more metals used.
nitinnun
the blocks in the pyramids, are made up of:
silicon dioxide (sand)
oxygen (59% of all rock matter on earth is too)
carbon
and possibly a little aluminum.
thomas trawoger used sand, water, and carbon, in/around his copper loop.
he SPECIFICALLY had graphite sticks (carbon), near the counter-clockwise coil, on the copper loop.
i have successfully used sand, water, and glue (glue is carbon/oxygen/hydrogen), in my glue cells.
the oxygen in sand, is negativly charged (paramagnetic?).
carbon is likely also negatively charged. because carbon powder conducts electricity.
so the blocks that make up the pyramid, conduct magnetism, but not electricity.
just like the water and glue in my glue cells, conduct magnetism but not electricity!
Drannom
it's a pleasure to see you explaining the TT pyramid as well as your own theory, i just wonder what it will be if you take some of your time to reread the Pyraman topics, it seem that a resonating pyramid will perfor a lot better , charging and downloading static charge 400 000 times by second
Pyraman explained well how to construct it, singning sang in recrystal copper,  resonating in the middle of the pyramid ! what the theory will be ?
is that tells something to you Nitinnu ?
nitinnun
go to toolsforwellness dot com, and look at their neutralization ring.
each of those bars, creates oscillations. because energy hits the end, bounces back, and travels until it hits another bar.
or until energy from another bar hits it.
i think that that is the function of the 2 grand galleries.
also notice how the grand gallery would have struck the stone plates above the kings chamber. taking away some of its frequency with it.
