First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
pese
Yiu domts see the spply cables !
you dont see the motor running ! (no prpellor or colored disk on it !
you see the multimeter schown zero !
than 5.00 if not nois of motor
than (another?) motor will be switched on (click) .
tha you see the 5.00 again.
After you se 0.00 , the magnet will be take off !
BUT the motor still running longer !!
Thean he will switched of (click)
than again . NOW we must switsch off AA !
What an cause if the Energy is free and selrunning.
last the phramide is placed in an room , ind angel-degree  paralell to whe walls of th rooms. !!
In over 99% the hoiuses are not buid exactliy to NS or E-W to the erth magnet field.
Dizend and mor you can find in ths fraudly Video that is make to give DESINFORMATION to the people to STOP more
exeperioences in ths sens what Trawoeger have make correctly.
I trust my meaning , you must not follow.
G.Pese
Koen1
Well I'm sorry but I can't really make heads or tails of your post...
I guess you are saying it is faked, but I fail to see all of your points.
What is that bull about you not seeing a coloured disc? My pc fan does not have a coloured disc, nor can you see anything but a hazy blur when it's moving...
Why would they switch on a motor to get 5 volts? That just doesn't make any sense; a normal battery would suffice, and would also not give any sound...
As far as the motor that doesn't stop immediately after the power feed has stopped: that is quite normal for a motor that is running. Motors never halt immediately.
I do not follow your remark "what an cause if the energy is free and selfrunning". What do you mean?
And as to houses not built exactly to North-South axis: that is a generalisation you cannot just take as a fact. Som houses are aligned N-S almost exactly, and it is well possible the house where the vid was made is alighned properly. We simply don't know, because we do not see a compass. But there is also no reason to dismiss the possibility just because most houses are not properly aligned. That's like saying there's no such thing as a black swan, because most swans are white. Similarly incorrect logic.
Please explain your last statement on "experiences" as it is not clear what you mean?
pese
Give attention to the video , yourself,
than i must not explain with my bad english longer.
give attention to all movement.
to klicking switches
to the meter
the meter the wholtime , it the motor make nois , if magnet is an , also off.
nothing is synchron.
can you see the mot running ?
possible another motor is running an is switched so that you cants see.
the "pic" of professional made videos for people that WILL belive all .
On an unproffesional Fraud . For people that all that is outside the table , must be trustfully.
G.P.
That man that explain ist not the "inventer" and know nothing from
this device .
See the video , give attention to ALL , hear all Noises that are not
nead to work.
You see nothing ! Even not that the "MOTOR work".
If you will see better magic-shows , i have som in my links for my children collected.
The Nagel-Show  is not so good...+++
Quote from: Koen1 on November 11, 2007, 09:01:49 AM
Tigrotto
Hi guys,
I gathered this weeks since I'm here on forum tons of fundamental/ teoretical informations about pyramid/ electric current generation. I'm about to start with the experiments.
The good news for those of you that are interested , really interested in these experiments is this :
Trawoeger's experiment could works, but...not as he presented/ showed there.
I'm Ph.Dr. and I studied ALL the theory related, also available Patents of Invention related.
My proposal is this:
Should someone work seriously with me on this matter, then write me back on private post.
I need only those persons really experimented this kind of facts.
Thanks in advance,
Tigrotto
Koen1
Why don't you post your usefull information here and discuss it with us?
Very odd to see that people are willing to discuss things here untill they rech the point where they feel they have actually acquired some usefull knowledge, then they tend to drop away from the forum and go private and secretive... What's up with that?
Either you have found some possible ways to explain and possibly even replicate pyramid electrical power generation, or you have not.
If you have, please just tell us about them instead of acting all secretive?
