First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Now Mr. Traw?ger has also published 3 schemes as PDF files here:
http://www.trawoeger-pyramide.info/project/index.html
Looks like the galvanic cell is energizing a special LC
tank circuit so the whole thing begins to oscillate and can output thus
more energy.
Although he said, that it is DC ???  when I remember correctly ?
I just only had a quick look, have to study it further.
Many thanks.
Tigrotto
Hi,
Waiting for Thomas 's extensive explanations , I'm curious:
Stefan, please answer to my questions if you understood this (my German is extremely low, !!!)
1. Copper frame is connected ( electrically to the pyramid frame and this is also the (+)???
2. Then, what is the (+) of the system?
3. How is connected the middle pyramid 10 foils capacitor ?
Thanks,
Dr. Ovidiu
P.S. Maybe the answer is in the German text , even if I read it attentive!!!
Tigrotto
Hi Stefan,
I downloaded them and I studied them this is why I did those three questions:
1. Copper frame is connected ( electrically) to the pyramid frame and this is also the (+) ?
Did you read the text in German,please? I read it even if I didn't understand German, I tried to understood...
I insist, veen if it looks simply, the missing of an electric circuit make these things not very easy.
Could you be so kind as to replay, even briefly to these questions please?
Here are why these questions are not so easy to answer :
A. Skizze2: What means 6 point? This is (+)??? Where have to be connected this 6 point of Skizze2 ?
B. Skizze2: The assembly is hanging from the top of the pyramid by means of point 3 ( see Skizze2) Should be an electric contact between this copper frame assmbly and the pyramid frame by means of (3) point hanging the assembly of the pyramid's top?
C. Look at the capacitor: Are we sure it is connected electrically between the two separate similar coils?
If the answer is YES, then take a look at SKIZZE3 : What means that German word ABGRIFF???
I think these are normal question of a person trying to replicate this system.
Thanks in advance,
Ovidiu
Point 6 is one output,
the positive output.
Have again a look at the highres picture ( click it for full size !)
at:
http://www.overunity.com/index.php/topic,695.msg4065.html#msg4065
There you can see, that the red cable comes from the iner copper hangings
and is going via the one copper plate cap to the positive output
and the other pole is fixed to the pyramid frame, which is negative
and it also goes to the other capacitor plate, which hangs there at 40 degrees down
from the copper pipes...
Hope it is clear now.
The inner copper tubing is isolated from the pyramid frame by a plastic holder.
So the positive pole is the inner left graphite rod from the copper tubbing ( position 6)
and the minuspole is the frame of the pyramid...
Pretty amazing,seems also some kind of one wire transfer
as the battery of graphite and copper powers the LC circuit in the center
but outputs only one wire from it and this might charge up the frame to the other
polarity, so that the frame gets negative potential...
Maybe it is also AC overlayed onto the DC voltage ?
Seems to be a strange circuit and setup......
but surely NEW, so no wonder nobody has yet found this,
as this surely is not wired up the "normal" way...
Well done Thomas !
Regards, Stefan.
