First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
CTG Labs
Neptune,
Anyone who knows me on here knows I do not sit on my ass doing nothing and that I have spent over 10 years actively building and testing devices, not sitting in an arm chair.
If we get all the details and people are able to construct a working device I will happily eat my words...
D.
fritz
Quote from: skywatcher on December 08, 2007, 11:18:38 AM
Quote from: pese on December 08, 2007, 11:10:31 AM
The device has NOTHING to work what my school physics or EE is explicable say to me.
I agree. In the context of conventional physics, the device is completely nonsense.
If it really would work, physicists would really have problems to explain why.  ;)
The idea behind school physics is that you get at least a glance from the most
primitive physical principles - and they show very straightforward experiments.
Even an electrical engineer is "tuned" to use available parts within their limits...
I think the problem is that if somebody sees a wound up wire - he thinks its a coil -
having a coil there makes him looking for a capacitor - then he can use the nice
formulas and is crazy as hell that he is able to calculate a frequency.
(a wound up wire can be a capacitor, an antenna, a delay line, a resistor,
a fuse, just mechanical (to avoid cables hanging around)...) ...(...)....is a wound up wire.
Or if you look on how its built - you have 2 coils and a capacitor in a very
compressed setup - because they are not separated nor shielded - you have
to expect that they work as one piece. you cannot assume that these are indiviual
parts....
Well, according to Thomas - you have the complete plans, you know every
material, every dimension.
You can calculate all stray and parasitic capacities, you can start to think
how the stuff would react to static and em fields of any direction ...
If you would see this setup in a context of very high frequency - some GHz -
everything makes a lot of sense. (even the gypsum plates).
Ok - there are no parts with printed electrical values on it ;-)  but this doesn?t
mean that it doesn?t operate in an electrical context.
If you would come as alien from another solar system - the way how we generate
rotational energy from 4-stroke engines  would be a very crazy thing ...
rgds
skywatcher
Quote from: CTG Labs on December 08, 2007, 12:04:29 PM
Same for me.  But i'm realistic, and such things are triggering my 'bullshit alarm'.   :(
Nevertheless i'm still hoping for positive results. People who already have invested much work into this project should continue, so that we will see if it's really working. I had not yet started working on it (only bought some parts and made some drawings) so i have decided to freeeze it until i see some positive developments.
skywatcher
Quote from: fritz on December 08, 2007, 12:09:12 PM
You are right. The whole thing should not be viewed in the context of conventional physics or electrical engineering.
I also don't think that the 'pyramid energy' (if there really is one) has anything to do with conventional EM fields.
If this would be the case, they could be easily measured with conventional equipment.
I have made some experiments with pyramids some time ago, and i did not see any unexplainable effects, and i also could not measure any unexplainable EM fields inside or outside of the pyramid. I don't rule out the existence of 'pyramid energy' but i think if it exists, it's something completely different, and not EM fields of any frequency.
CTG Labs
I did an experiment about 7 years ago (repeated several times) where I had a copper wire frame pyramid and a paper pyramid.
I took 3 leaves from the same branch from a plant outside and placed one in each pyramd and a 3rd as a control.
I waited for them to dryout and die.  The control leaf rolled up, went brown and crumbled, the one under the paper pyramid, did not go crumbly and the one under the copper pyramid stayed greened and did not roll up.
In the book shape power it mentions how a group of engineers using extremely sensitive gauss meters have been able to detect a magnetic field around pyramids (made from any material) which gets stronger the better it is aligned with the earths magnetic field.
D.
