First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Pegasus
@Tigrotto
I completely agree with Skywatcher when he says:"....even when there is a voltage, but no power to measure in the sand, it would be interesting, if this voltage only occurs after putting the sand into the pyramid for several hours. Of course you can measure voltages everywhere with a high-impedance voltmeter, but if you can measure a voltage after 'pyramid treatment' which is significantly higher than the voltage without this treatment, then i would also consider this as remarkable"
Maybe you have not understood the real meaning of my post on the experiment.
I'm sure that my "cup of sand" is not able to power even a led,but probably,accepted science cannot explain why I got voltage in it......
Cyrano.
jeanna
Quote from: Pegasus on December 15, 2007, 09:16:18 AM
If I remove the electrodes and I insert the probes of the voltmeter,DIRECTLY in the wet sand exposed to the pyramid,I got voltage.This phenomenon  resemble piezoelectricty,but I'm not sure,because I havent take measurements with the same sand -not- wetted.In these experiments .If I use sand not exposed to the energy of the pyramid,I get pratically NOTHING,no voltage, in every mentioned cases.
Now I ask to people that have the possibility to repeat the experiment
Cyrano
Hi Pegasus,
I am here to keep me from  impatiently fiddling with the probes on my meter . I am doing only controls right now and I do not have a good pyramid yet. I am only doing the part with the salt water in the sand in the glass jar. Here are some results:
If I stick the probes directly into the
dry sand   0.000v
5% salt water  0.005v
graphite pencils as rods shorted 0.00v
all as expected OK
now, I wetted the sand with the salt water. at first the reading was 0.001 then I noticed that it changed while I was holding the probes. So, I stuck the probes into the damp sand and as I have been watching and waiting for about 45 minutes the voltage has risen continuously and now the voltage reads 0.090v I am not even sure it is slowing down.
I suppose it could be that I am slowly shorting my meter and the battery which the meter uses as a reference is slowly draining.  >:( ???
but no up and down motion - just steadily going up.
I will continue to report. Maybe I will make a foam pyramid today while I wait.
jeanna
Walter Hofmann
Hi all.
I had a big surprise yesterday I had to take the converter apart and start over because I brook one of the graphite rods. now I empty the sand totally dry out the pipe and started over filling with sand then putting the two new rods in fill up the pipe and closed off, fill saltwater. then I put it back in to the pyramide frame insulated at the same spot like before and to my surprise the voltage reading rods to pyramide frame showed only 0.004V. I added a bit more of the saltwater nothing changed. the first setup what had exactly the same material for everythings and even the same amount of saltwater showed right a way 0.231V fluctuating to 0.482V.
this is very strange.
did somebody expirience similar things?
please post it or send me PM
thanks and greetings
walt
Pegasus
@Jeanna.
Its not clear to me if you have exposed the sand to the center of the pyramid.By the way if you get raising voltage  during the trethment,is is a good sign.I have measured my voltage after removing the pyramid and I have noticed the capacitor discharge effect.Not doing the exposition on my sand it doesn manifest any effect.Completely inert.I think that if we get differnt results,is becuase we dont use the same source of materials as starting base,so we can get a lot of different varations.even with differnt pyramids,different locations,etc.etc..
If you have the possibility,try to put into the wetted sand a sheet of aluminium and one of copper,and measure the output,and compare with a test control outside the pyramid.There was rumors in the past about the strange effects of these two metals subjected to the energy of the pyramid..Maybe is true.
@All
I counsil to everyone to finish their pyramids and show the pics to Thomas.There is the possibilty that he will send the new instructions only to builders.If you got the instruction dont post it here or elsewere without his permission,because there is the possibility that Thomas will leave us,and without his help we will are not able to finish our work,even with every details.
Cyrano.
Pegasus
Doing a search on the web I have found various posts and articles on Thomas  sharing his invention .WRONG!
Thomas has expressly said to not talk about these things outside the forum,otherwise he will leave.
Consider that acting in this way we augment the possibility of danger to Thomas and his family.And consider that without Thomas we will are not able to run our pyramids...
I ask myself why people are so stupid........
Cyrano
