Magnetic force and distance
Started by Shinecat, January 20, 2006, 08:17:38 AM
tropes
Good links but none of these links answers the question," What is the attraction and repulsion force of 2 given size magnets at a given distance?"
For example: I have two Neo 40 disc magnets attracting each other 1 inch apart. The surface area of each magnet is 11/14 square inch. The magnets are 1" in diameter and 1/8" thick.
Peter
gyulasun
Hi Peter,
I found this link: http://www.magnetsales.com/Design/DesignG.htm
And this: http://www.magnetsales.com/Design/Tools1.htm and this: http://www.magnetsales.com/Design/Calc_filles/PullAndPushBetween2DiscMagnets.asp
I understand the calculations are approximations.  Use material N39H for N40 to approximate it ( no N40 material is included...)
Gyula
tropes
Quote from: gyulasun on September 05, 2007, 10:06:12 AM
Hi Peter,
Gyula
Thanks Gyula
Good calculator at magnetsales.com. The answer is given in " gauss at X" . How do I convert that to lbs.?
Peter
ken_nyus
Quote from: tropes on September 05, 2007, 10:22:25 AM
Thanks Gyula
Peter
It looks like the "push" and "pull" numbers below the "guass at X" are the forces in pounds.
gyulasun
Hi Peter,
At this link I included in my previous post  http://www.magnetsales.com/Design/Calc_filles/PullAndPushBetween2DiscMagnets.asp you get not only Gauss at X but the attract and repel force in Pounds so you do not need to convert.  (By the way they have a conversion help here: http://www.magnetsales.com/Design/Tools1.htm#units )
Gyula
