Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 50 Guests are viewing this topic.
libra_spirit
Paul L,
Good to see you again! I miss our long bouts of sparring over diamagnetic field theory! You need to step into the nucleus of the atoms to cypher nature. The atom has three components to achieve sustainable motion.
Nice to see you are still out there, after blowing the lid off all the free energy with metglass and ambient heat absorption! LOL!
I suppose you still don't believe in Isatope chains liinking together in Aluminum or David Hamel. Manipulation of the nuclear mass, mass vibration effects, or Coherent torsion fields as we experience in Joe Cells running engines in cars. Had that experience this last summer.
I present the NMR course from Dr Hornak to give people a visual of what the nucleus of the atoms are doing. It is an excellent visualization and conventional science background. Some good math in there also, and you still have to admit the major weight of the atoms is located there also as well as the neutrons, center of gravity and strong force of the atoms, where the sum of the parts is heavier then the combined result of the nucleon assembled. First known gravity effect found in nature, and nobody notices. As well it can be tilted along with the external magnetic field no matter how weak the protons field is. My numbers are close enough for weak magnets, that are well below 1T to provide a feel for alignments of magnets and match the numbers where I find the vibrations to manifest with my equipment often enough. They show the order of magnitudes, if you want perfection then use the calculator and measure your magnets, I provided that URL also. A function generator up to 2 Mhz is enough to get these vibrational fields to rise up using scalar bismuth coils.
I would love to see you attempt to explain how the pulsing wheel can generate overunity power for Chas Campbel only by having a loose belt. Hmmmm maybe a mass vibration effect?
As far as the magnetic field not having a coherent precession, well what is a coherent magnetic field anyway? I have an experiment that will allow you to feel it as a cone. When you take two magnets and join them in attraction you get only two poles and one blotch wall. Where did the other two poles and blotch wall go anyway? One maget is now only a north pole and one is a south pole and only one blotch is left. A coherent magnetic field is "one field" end to end and all its parts become only a small part of the one field. One atom may now be a North pole and one atom a south pole. Break down an electron, and you get the same thing. Quarks forming one coherent field as an electron. Break down the quarks..... Neishiem Harrimen is excellent on the nature of fractals, leading edge physics. The field forces also are fractals.
If you cut a magnet through its blotch wall you get two pieces that attract, if you cut the magnet length wise through the poles you get two pieces that repell. In a magnetic field there is both attraction and repulsion.
If you want to feel the cone of a magnets pole wrap a coil on it, and pulse it with a low frequency say 100Khz, now palm the end of it in the air, see if you can feel the edge of the vibrational field on a hand. The cone joins the end of the magnet right where the magnetic field stops attracting metal.
Slip a copper sleeve over a long string of neo magnets, mine was four feet long. Slip an iron pipe over that to bring the field back around, and another copper pipe over that. The two copper pipes will spin against one another and create a strong torsion effect. If that does not convince you torsion fields are real nothing will! Set off the side and it will blow your pineal gland out the top of your head and might also make rain as the pressure drops. Palm around the string and you can feel the pressure of the cones at approximatly 45 degrees off both ends. There is truly a vibrating field produced when a stationary magnet hits a diamagnetic material. Cypher that however you want, its real.
http://magnetism.fateback.com/Tube_Device.htm
http://magnetism.fateback.com/OZ.htm
Don't expect to find an answer to this in conventional science. Its not there.
Take care,
Dave L
[Rogue scientist and vibration sensitive]
LightRider
Quote from: capthook on April 14, 2009, 12:20:23 AM
Why, with very limited data , have so many chosen to ignore one of the few we actually DO have?  The video that shows an extended run, with a fixed camera and large viewing angle.. (but NOT showing the start-up - yeesh  ::) )
The graph below is taken from LightRider's video #41 graph.
This section is when Mylow begins talking on the video.  The graph appears to show nothing more than a rundown of a flywheel.
"Oh, the magnets were depleting" :
but it ran for 18 hours @ 140 RPM without slowing down, but not for 4 min.??
"Oh, it was a hoax video to trick us into thinking it wasn't real because the MIB"
but he was too 'simple' to hoax us in the earlier videos, but now he's real good at it?
"There was a lunar eclipse in progress that caused a time-warp/space shift"
oops, I made that one up!
It seems logical (rundown of a flywheel), and even the waves of acceleration in the first part of the video is not a behavior that one would expect from a magnet motor which is left to itself.
(it is very unlikely to be due to a disorder of video compression simply because there are several data sample confirming the acceleration and deceleration )
This time-warp/space shift will soon cause a suppression of all backup videos if no new scientific evidence is unveiled... again, make copy if you want them ;)
(suppression: may 1, 2009 : http://www.youtube.com/user/LRCan1)
Thanks,
LightRider
LightRider
Quote from: AnandAadhar on April 14, 2009, 04:14:08 AM
I agree, as I said in my post (page 202) before, that the thing is slowing down as soon as he starts talking. Such depletion as he claims I don't believe in. No way. Its a good flywheel as far as I am concerned....
The depletion would be most likely over a longer period rather than quickly as the last video shows.
Thanks,
LightRider
PaulLowrance
Dave L., I'll keep it blunt as usual, and short. Years ago I spent too much time pointing out your errors, and you never listened. You ended up saying there was nothing anyone could say to change your mind. You're not a liberated being, so you're only playing guessing games with your intuitive/psychic science. In all these years you still haven't produced that "free energy" machine. The path I took, mathematics from conventional physics, provided a certain type of diode array made with ZBD's that produces a measurable DC voltage across a load, and the mathematics based on conventional physics shows diode arrays made with nanoscopic diodes will produce kilowatts of power. My point is, reconsider our previous discussions and stick to real science, not La La dreamy science -->
http://en.wikipedia.org/wiki/Online_degree
http://en.wikipedia.org/wiki/Self_education
PL
p.s., All of your NMR numbers are incorrect. See one of my recent post for the correct numbers.
