Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
AquariuZ
Quote from: zapnic on May 17, 2009, 02:07:58 PM
look at this
this is the way do
leave out your logic or brains and start do some weird stuff
http://www.youtube.com/watch?v=TkmR5Ymsdys&feature=channel_page
Zapnic, you have created a real stonehenge model!!
:o
What makes it work is well Mr. Hand as TK lovingly calls it.
lumen
@AZ
QuoteThe surfaces of the magnet seem different (because of marking). Can that be a factor?
When I first noticed the effect I only marked a little dot on a non surface edge because I didn't want it to taint the test in any way. It does not matter which side of the magnet I mark the results are the same.
It also does not matter if I flip over the aluminum sheet, or rotate it 90 degrees or even rotate it in the earths orientation, the results are always the same, SOUTH side drags more or does not hook like the NORTH side.
I need to do some time tests to see if it is an increase in drag or just some hooking effect. I still cannot understand why there would be any difference.
zapnic
Quote from: AquariuZ on May 17, 2009, 02:23:41 PM
:o
sorry it's not me
it's great rdelos1disequade
deseret
MyLow's YouTube account is closed.... agian ...!
nyctuber
Mylow deleted his channel AGAIN? What happened this time....
Makes zero sense.
