Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
Grimer
Quote from: hartiberlin on March 22, 2009, 05:17:07 PM
Hmm,
maybe you are right Paul,
it really needs a better verification of the polarity of the Mylow magnets.
I still found  another magnets, that looks simular to his
stator magnet:
http://www.buntingmagnetics.com/alnico-u-shaped-magnets/
And it says that it is magnetised as a horshoe magnet.
Good find. CU606 looks the spitting image of his stator.In particular the D/E ratio of one and a half.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
Grimer
Quote from: X00013 on March 22, 2009, 05:37:48 PM
I'm gonna blab for a second,    Ok, so I'm back from work and check on progress, so I watch this MYLOW video http://www.youtube.com/watch?v=ji5QUhI1IQE&feature=channel_page
           and I see the Tube User named whgage calls him an idiot, so I click on whgages' profile page (  http://www.youtube.com/user/whgage  ) , and I see MYLOW has found time to post a comment, "if you dont mind please dont call me an idoit i prefer more like a lire ok" . So I ask this, Why refer to yourself as a liar?
No doubt he knows he can easily prove he's not a liar.
X00013
Quote from: Grimer on March 22, 2009, 06:01:28 PM
You see , that's a problem, A guy calls me an idiot, and my comeback is, "no, I'm not an idiot, I'm a liar",  WTF?
wattsup
@sterlinga
Since Mylow put back the videos, this bodes very well for both his character and his intentions. One would presume that if this was a hoax, the hoaxer would have felt the heat and not put back the videos and stuck to his MIB story. So good.
But this still leaves a wizzing sound that coincides at two wheel start-ups in a way that you could not say that an outside vehicle would cause such a sound twice. So I got to thinking about this and would ask that next time you speak to Mylow could you please ask him to do a quick test.
1) Just use his video to record whatever and bring a magnet near the camcorder and see what happens. It may be that while he was making the video, he was very close to the magnets at start-up trying to show the stator/rotor magnets close enough for all to see and maybe this caused the video microphone to record the camcorders internal motor. Hope I got this across well enough but it has bugged me since.
2) As for a replication without those original magnets, for both the stator and rotor, placing simple neos on a thick iron backing will probably do the same thing since the sides sticking to the iron will be lost in the structure leaving only the protruding ends. If using neos, I would guess the distance between the rotor and stator will have to be wider in order to still maintain a weak attracting and repelling effect.
3) Regarding the four in a row rotor magnets, I think this was done this way simply because the diameter of the wheel versus the spacing between each six sets was not really pre-calculated to fit perfectly and that fourth magnet was used to occupying the obvious over spacing. This tells me the actual build is not that critical and the the real effect can be accomplished in many ways.
So I guess this only means one thing.
MORE FUN FOR ALL!!!!!!!!!!!!
Grimer
Quote from: X00013 on March 22, 2009, 06:05:54 PM
He didn't say he was a liar. He said he'd rather be called a liar than an idiot. Wouldn't you if you knew you could prove what you claimed?
