Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
Low-Q
I think the impossibility in building a working magnet motor is the boost inventors need to try anyway. What is more temting than trying to make the impossible, possible? No one can stop us trying - even if we fail over, and over, and over, and over, and over again.
Vidar
Justalabrat
Quote from: miki02131 on March 28, 2009, 02:12:27 PM
An all passive and permanent magnets device will never be able to operate let alone yield OU.
Hey! never say never!
CLaNZeR
Last update from me today as time for some food and spend bit of the night with the family :)
After trying to manually place the magnets a few times and then ripping them off after holding up Mylow's pictures against it and comparing I decided to go for this layout attached.
All Rotor magnets now in place, so tomorrow will start on the Stator magnet holder.
http://www.overunity.org.uk
Omnibus
Well, @CLaNZeR. it happened earlier than I expected. Good for you, buddy.
BEP
The only reason I'm building one (shop is cold - I'm thawing my feet right now) is to watch some folks gag on crow.
Maybe this one will also fail. At least I'll have a 10 minute video of me gagging on crow. Don't expect me to share. I have unique tastes.
I have the materials, time to kill. What the he77? The more insults and book thumping the better.
I'm no fool. Personal experience tells me this will fail in one way or another. Even the most promising ones will simply stop functioning - and that is without demagnetization.
BTW: De mag is most likely not an issue here but not the way discussed. Simple iron magnets (ones magnetized after manufacture) don't generally loose their magnetization in repel. The field simply becomes contained within the iron shape. You can cut it in half and both halves we be magnetized again.
Same problem happens on large standby generators that sit too long (yes, I know they are actually alternators).
On those a field flashing circuit is provided.
So, if this is a problem, and you know the actual pole configuration, you just wind a coil around it. Hit the thing with a high amp pulse of DC and it is back in service.
Feet have feeling again....
Later
