Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
jester
Quote from: wattsup on April 04, 2009, 08:54:56 AM
So what happens when you put two magnets together. or near one another. The magnet field doubles. When you put 3 it triples as one. If you have 2 sets of 3, the whole space will have two triples intermixed making one dual flux. Then the inter 6 set spacing being large enough to enable the stator to reset its own field as it transfers from one 6 set to the other.
You need to play with only 6 magnets on the wheel. Once put on, take your compass and see how far the total field extends left and right into the wide open spacing and write down the length. Then compare this to how far one rotor magnet field extends left and right and write down the length. This will give you a realistic visual idea of the 6 or 7 set flux. Then play with the inter spacings and stator position to get the stator to pass through.
In mylow's wave video
http://www.youtube.com/watch?v=T2VX89gJcbU
The tools he uses to show the wave reminded me of an ant farm with the contents ripped out of it - add iron filings and seal it at the top.
Picture of the type of ant farm I mean.
http://www.ant-farms.com/ant-farm-reviews/giant-ant-farm.html
It would be interesting if a modified ant farm could help show the position of the wave as you enter and exit each set of rotors.
wattsup
@TK
Thanks for your video. It was well prepared and your set-up is top notch. I understand perfectly well what you are trying to show here as this was my initial and very valid concern as I am sure it was for most builders, etc. The fact though is this cannot be compared in the same way using only one magnet as it is already obvious without doing the whole testing exercise that the wheel will turn longer when the stator is removed. The point here is that it is not a single rotor magnet that is doing the actual Mylow effect. It is the combined effect otherwise if your testing could extrapolate the Mylow effect, then his wheel should not turn at all since all the rotors combined should have a combined adverse effect on the ability of the wheel to turn. But I do appreciate the manner is which you presented this.
Just to expand, what Mylow does is not a drastic pull start as your string test is showing. He is only placing the start into the directional flux and lets it go on its own from there. Granted the wheel momentum has a play in this and we already know this, but if all those magnets had a "negative" quality, you would agree that wheel should not turn regardless of the wheel momentum as shown in your tests.
So, does your conclusion mean you will not put any more rotors on that wheel and stop this project. That is my question. lol
nyctuber
This TinselKoala guy has a rather enormous chip on his shoulder, huh. Not enough attention from the overunity forum, I'm guessing?
Grimer
Quote from: HiggsField on April 04, 2009, 09:08:07 AM
@FuB@aR3D
Sound tracks can easily be dubbed onto the video....
True, but wouldn't they have made it a teeny weeny bit more obvious and not almost below the threshold of perception.
Sorry Higgs, you are postulating a degree of Machiavellian intrigue which is unbelievable. The MIB are not that clever. They are rather stupid actually and their knowledge of science is probably absolutely pathetic. It's far more likely you are a paid critic (and I'm not suggesting you are) than that video had a dubbed sound track.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
Paul-R
Quote from: nyctuber on April 04, 2009, 09:32:00 AM
There are several people who enter a thread and discourage everyone until the thread dies.
If Stefan does not start using his Yellow Cards and his Red Cards, he may find that everyone
migrates to a board which is usefully and properly moderated.
