Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
capthook
No comments on the rpms STATED by Mylow and the rpms SHOWN?
http://www.overunity.com/index.php?topic=7039.msg168528#msg168528
140 RPMs is quite fast!?!
(A) 77 RPM : Mylow claims it has run 26 hours continuous in one setting. Mylow says he has seen some deceleration over time.  It was rotating at around 30 rpm in the first fifteen seconds.  After about five minutes, it was spinning at 77 rpm.  He estimated that it loses about 1/2 rpm every hour or two.
(B) 140 RPM : Mylow claims it ran 18 hours @ 140 rpm / it had been running around 18 hours continuous, with no apparent slow-down.
(C) 10 RPM : Last video: RPM approx. = 10 rpm
(Initial speed of rotation about 7.2 secs. After noise in 12/13thsec it is about 4.5 secs. At the end of video about 6.5secs.)
(D) All other 'running' videos similar to (C)
Comments:
- Mylow has claimed upper RPMs of 77 and 140, but has only ever shown approx. 10 RPMs
- Mylow has claimed 18 hr. run times with no apparent slow-down, but the latest video shows a significant slow-down over only a few min.
- (A) and (B) would appear to be very questionable and even fabricated data
The graph below is taken from LightRider's video #41 graph.
This section is when Mylow begins talking on the video.  The graph appears to show nothing more than a rundown of a flywheel. (with the data not perfectly smooth because of youtube compression?)
This would indicate to me that Mylow is doing something off-camera for the first 4:30 to maintain rotation (or even a video loop etc), but once he starts talking, he is unable to continue whatever he was doing to maintain rotation.
Why would it spin at a relatively constant rate (with a few dips, possibly showing where the rotor is spun up by compressed air?) for the first 4:30, then suddenly drop off to an apparant flywheel rundown for the 2nd half when he starts talking? (from ~4:30 on, it IS a flywheel rundown IMO)
(and NO, magnet degaussing would not explain this)
plengo
Quote from: capthook on April 06, 2009, 10:46:03 AM
Comments:
Why would it spin at a relatively constant rate for the first 4:30, then suddenly drop off to an apparant flywheel rundown for the 2nd half when he starts talking? (it IS a flywheel rundown IMO)
That is exactly what I was trying to tell everyone when i did the first analysis of his 7 minutes video and the sound. Thank you, you did a great job explaining in plain terms.
And Omnibus said I took my observations from "thin air". Is that right Ominbus? Dont you think that the DATA is demonstrating beyond any doubt that the only logical conclusion is that this wheel spinning is really not spinning on its own?
Is it acceptable to conclude it is very possible and likely that the wheel is spinning but some other means than the magnetic fields?
If not, what possible reasonable explanation would you propose? Again, even if Mylow has a real thing, all he demonstrated so far FORCEs us to think it is lacking evidence to eliminate doubt.
I wish more than anyone this was not a hoax but the real thing! But my mind does not allow me to accept that yet.
Fausto.
Grimer
Quote from: plengo on April 06, 2009, 10:19:15 AM
Amazing. If this beautiful analysis is right (which I assume is) is not that strange that the motor accelerates when the camera is not showing the motor???
Fausto.
It doesn't. Are you incapable of understanding my post or are you just perverse.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
plengo
Quote from: Grimer on April 06, 2009, 11:09:59 AM
Ops, sorry Grimer, I quoted the wrong post.
No I am not perverse. Back to your post, since I am here now, I agree it would be a little difficult for Mylow to nudge things by hand thats why I think he is using pressure air or some other form of propulsion system.
Fausto.
dankie
Deleted by moderator. @Dankie cut it out. No more insults.
