The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
pauldude000
Quote from: pix on January 18, 2022, 10:16:57 AM
Hi Paul,
In the patent there is clearly stated that a solid conductor may be used as collector, please see attached below.
Of course 3 phase current could be used to drive coils, to get resultant travelling wave. I am going to use  industrial AC motor drive I have- input is 230V / 1 phase/50 Hz ,  output 3 x 230V , 50-2000Hz.
But the simplest way to achieve travelling wave is just loaded transmission line, like in the patent main drawing.
Very interesting ,lenzless way of current drive- owned by Atomic Energy Commision to heat plasma in Tokamaks.
In fact TPU may be a spin-off of that technology.
Cheers,
Pix
After examining the patent yet again (several times so far), I got to thinking about the 3-phase alternating current issue. As the schematics are wired, it won't work. However, a little rewiring would hypothetically allow it to work.
AC is a push pull system. In the schematic, all of the coils are hooked equally to either a "hot" or the "ground". This will cause half of the coils to be of reversed polarity during any particular cycle. For the magnetic field to stay oriented in one direction, for every portion of an AC cycle (+ voltage or push, - voltage or pull), one coil for each cycle has to be wired backwards so that the current is always flowing in the same direction through all of the coils. Considering three phase, You would have a normal, normal, normal, at which point the three phases switch to negative voltage, and the last three coils would all use a backward (ground side of the coils for the first three coils would be power input side for the last three) hookup scheme to achieve this.
As far as the coil setup and developed magnetic field is concerned, all of the voltages would then be "positive".
Hope this helps.
With that thought in mind, I might try it, lol.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
Nali2001
 Have not been up to snuff with the 'latest' (as in the last 10 years) developments regarding the TPU replications. So lately I was wondering whether it was ever figured out (or maybe even replicated?) why and especially how the TPU allegedly had the gyroscopic effect?
We can't really say that there is a circulating mass so it is probably a 'feelable' interaction to some other field? Were the internal pulses so strong that this had a real pull on the earth magnetic field? Or even some gravitational thing? Was this ever found out? I mean if your coil gets an feelable attraction or reorientation to the natural magnetic field then you have to develop some pretty strong magnetic field on your own I would think?
forest
How about Barbosa and Leal patents ? Electron trap
