One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
PYRODIN123321
can't seem to get mine to work, the coil is way too small I think...they only sell little spools of wire at radioshack....have to order on-line.....sigh....
Peace.
nievesoliveras
@jonnydavro
Why dont you use the invention as a normal motor like this:
Jesus
Pirate88179
Quote from: PYRODIN123321 on May 29, 2009, 09:07:27 AM
I used those same Radio Shack rolls of wire for my replication and they work fine.  I used Lidmotor's "transformer" style coil. (He uses RS wire spools too)  All you do is to take the 2 smaller wire diameters in the 3 pack, (30 and 26 ga. I think they are) and wind a bifilar coil.  The trick is that you will run out of the 26 ga. first as there is a lot less of it.  Keep track of the end of that wire by putting it out through one of the drilled holes on the top or bottom, then just continue winding all of the thinner wire until gone.  This coil is very efficient and I run my Bedini replication using this design also.  I think Lidmotor also has wound a trifilar coil using all three spools of wire until they are gone.
If I have not explained this properly, feel free to pm me and I will try to do a better job of it.  This is a great coil.
@ Jeasus:
Interesting idea.
jonnydavro
@Pirate.Hi Bill.Those magnets that you have ordered will work fine.Mine are N42 grade too.I would start winding a pickup coil while you are waiting for them to turn up as you will be smiling when you test that.Also are you any closer to trying the one mag bedini on your earth battery and have you modded your circuit? Can't wait to see what you have planned.Regards jonny.
@Pyrodini.Don't be to hasty.Your coil may be fine.Post some details off your setup(any pics) and we might spot something that you haven't.Regards jonny
Pirate88179
Jonny:
I have been in a holding pattern waiting for my 650 Farad supercap to arrive.  It is due in next week!!!  Yes, good idea, I will get some wire today (Radio Shack) and start another coil.
Once this big cap gets here, I do believe I can run this motor from the EB.  No, I have not made any of the mods to lower the amp draw yet.  Do you have a page reference where these are described in detail?  I guess I should look back on this topic for them.  I will probably need a little help with the mods.  I will let you know.
Thanks.
