One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
jonnydavro
Hi.Today i did an experiment which was suggested to me by MoonSpySudio's.This was to fill my testube satellite with water and see if the two 6mm neo sphere's  could overcome the inertia and form a vortex.Here is a vid regards jonny.
http://www.youtube.com/watch?v=1m6gGvTbApY
nievesoliveras
Quote from: jonnydavro on June 19, 2009, 06:28:42 PM
Excellent!
Years ago I saw in a laboratory the way they used to mix ingredients on a large glass beak.
They put a magnet inside the glass with the ingredienst mixed with liquid and a motor with a rectangular iron bar was run under the glass beak and the ingredients were stirred and mixed thorougly.
With your setting it is easier and does not need to raise the beak on top of a stand in order to accomodate the motor under it.
Yours work with the coil at the side and no danger of getting caught on the rectangular iron bar of a motor.
Jesus
gadgetmall
Hi all . Glad you all are having good success . I on the other hand have given up .I cannot get a single magnet to spin at all . A rotor with 4 magnets spins great . I have tried three  different coils one has 5 wires . a 5 filar . the second was a trifilar and the third is a bifilare . none will spin a magnet by itself. I have tried ball magnets . rattle snake magnets . tube magnets . all diametrically magnetized . I have tried 12 volts all the way down to 1.2 volts .and every transistor from 2n3055 mps06 2n2222a all My germanium's . It wont work ! the only difference is i use a capacitor to store the extra charge and i also monitor that to see when the benini is working . It will produce plenty of voltage as long as the magnets spin on its own force but there is no repulsion upwards to keep it up and spinning .there is when a rotor whit magnets and a bearing wheel ,not with a single magnet .   So i will not be showing it on the earth Battery /Jt demo on th2  2 7th . / Dang . I would have bought one if some one could make one that works on 1.2 volts . Any one ? I now don't have the time to experiment anymore with it . The thing is i have 7 Bedinis . two run constantly OU and the rest are scattered in the PV Battery room and Golf cart and several other battery charging applications . . Bummer.I really wanted a Satellite Bedini . It would have been great exposure of Free energy as i have all the containers and coils and ball magnets . they wont spin either . Can some one wind me a coil that works for a price  ? I have everything else . I have had 0 sucess with a lidmotor coil i wound .I will Buy a COil ,Its proper core and the magnet that you use to spin on top of it . I need it kind of fast if there are any takers.
Gadget
retrod
Quote from: gadgetmall on June 20, 2009, 01:21:54 PM
Gadget
@Gadget, did you try reversing one of the coils? Another thing is make sure your diode across the base/emitter junction is correct polarity and a good one. Those two things can be show stoppers. The circuit has to work, I even made it work with tubes!!!
Tonight I made an astounding discovery, ok, it's not astounding  :).
http://www.youtube.com/watch?v=VUBXmvCigBg
Dave
Pirate88179
@ Gadget:
Yes, I agree with Retrod 100%.  The Lidmotor coil and the basic circuit should be easy for you, considering what you have been able to do.  I have still not modded my circuit like Jonny's with the cap and relay but it works all the time, every time.
Tomorrow, I hope to replicate the plastic tube experiments as I found one.  I have dismantled my plate set-up and have removed my iron core form the coil.  I have a lot of catching up to do but, I want to try the high-speed turning of a single sphere and then the pair like Jonny has been doing.
I would have wound another coil but my local RS is out of mag. wire.  So, I have to make do with what I have.
Gadget, I would ship you one of my coils but, I agree with others that it is probably something simple that has been over-looked.  My first coil, I took painstaking measures to get just right, no overlaps.  It worked.  My second coil, I was in a hurry and it was not very neatly done but, it works as good as the first one.  Possibly you have a bad diode or other component....this does happen as you know.
