One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
Mk1
@gadget
Nice video ! keep the good work, tell me witch mk would you like 1,2,3,8,hv ...
Also do you have any idea on how to make relay triggered jt at 6 or 12 volts ?
Mark
nievesoliveras
Quote from: gadgetmall on June 25, 2009, 07:11:27 PM
@all heres a video showing this replication with the addition and showing you what i mean . Its not a trick and i'm not showing you anything tricky as i never do . It does what it does all day today .It now up a few more volts .
@Jesus . thank you . you can make this one  . i am sure .
http://www.youtube.com/watch?v=oIrOYOXLuvQ
Gadget
To make a replication of your excellent work I will need a detailed schematic.
Are you going to share with the public that information?
Jesus
gadgetmall
Quote from: Mk1 on June 25, 2009, 08:04:15 PM
@gadget
Mark
Hi Mk1 . thanks for dropping in and checking out that thing i did . Yes the one we talked about 800 HV ,, and yea you buzz the relay and interrupt the primary .Right ..I know how . You know i am or want to deal strictly with 1 volt stuff . this bedini is nice but not tuned to my liking However if it runs all week long on My dead sla i will have to let it ride !!!!
@jonny i am going to mod you schematic components to match mine if you don't mind . ok ? Really the only difference is the two caps on the secondary output . i took one wire from the positive connection there and ran it thru My monster sk3606 rectifier/diode to the positive terminiam . the other secondary wire (neg)is not needed ,,
Gadget
Mk1
Quote from: gadgetmall on June 25, 2009, 10:48:08 PM
Gadget
Do not worry i will use a 6 volt relay jt at 60hz powered by a 1.5 volt jt at 40mhz
You get the picture ?
Mark
i will need to buy some wire to fill that order , i will asap.
But think about relay thing !
gadgetmall
One more think . you have to remember that this voltage i am feeding back is not true STATIC VOLTAGE ANYMORE because i run it thru caps which make that BEMF voltage have Current . So caps do store AMPS before it hits the run battery . they are getting some push !!remember this battery was 3 volts trashcan material 6 or 7 days ago . i just decided to run it for the davro seup cause it was handy and had wires on it:) it did charge up to 5.99 steady . we will see . tomorrow is the cap test ,that is ULTRA CAP test /
Gadget
Nite nite
