One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
nievesoliveras
@eric64
If what you want is to learn electronics from basic to advanced, download the pdf courses offered free at:
http://www.allaboutcircuits.com/vol_1/index.html
Jesus
xenomorphlabs
@Eric: Bill is right, Youtube offers a lot of informative lectures and as Jesus said allaboutelectronics too.
If you do the beginner`s courses build a few of the example circuits like hooking up a battery with a switch and resistors/capacitors and measuring voltage/current.
Get yourself a simple multimeter (a device that measures voltages/current/resistance) like this
http://www.radioshack.com/category/index.jsp?categoryId=2032055
an experimental modular circuit board like this : http://www.radioshack.com/product/index.jsp?productId=2734155  ,
some wires like these http://www.radioshack.com/product/index.jsp?productId=2103801
cables like these (really helpful) http://www.radioshack.com/product/index.jsp?productId=2062236
and the components you find in the courses.
Then when you reach the level of building a single transistor circuit you are actually already in the league to build a simple Bedini (One magnet if your budget is short, or the monopole/schoolgirl circuit if you have a bigger budget {more magnets $}). This will teach you about coils.
Learning by doing is your biggest friend, have fun ;)
You should familiarize yourself also about safe handling of electric devices that can cause shock if you don´t know anything about it yet.
Good luck !
gadgetmall
Quote from: nievesoliveras on June 26, 2009, 12:03:37 PM
@all
Here is the graphic for your consideration.
Jesus
Perfect ! Thank you Jesus . You have got One Nice talent Cleaning Peoples Circuits up . Your Great  :)Yes the caps are correct . think of them as a battery. I have been too busy so busy that @ 10 pm I fell asleep at the chair and woke up this morning at 9 ,with a back ache!Busy week no experiments but its still running . i readjusted the 10kpot check the volts and they are at 6 . 59 at 9 .05 am est . Not sure what abattery would do at the secondary . someone try it if they get the time and have a part simular to the sk3606 that allows feedback Ok L8r
Gadget
xenomorphlabs
@gadget:
What part could come close to the SK3606 diode? :)
I have extracted from the spec sheet that the 1N4003 comes close regarding voltages, but there must be something unusual about the Sk-Diode that no other rectifier has.
I am assuming it is non-radioactive, so the switching times must be important or any other parameter of it.
I will run my circuit tomorrow again with the caps being poled like Jesus has drawn it.
I was too certain that the cap polarity would equal the charge battery polarity and obviously i was wrong with that.
Sorry Jesus about that Still having a hard time why the caps are oppositely poled that the charge battery, but unusual results necessitate unusual methods ;)
xenomorphlabs
@Gadgetmall and Jesus:
Please forgive me to be so finical about it but i am still not sure about the cap polarity because of gadgetmall`s comment:
QuoteYes the caps are correct . think of them as a battery.
The original charge battery had its negative pole on the right and was connected to the positive of the source battery. Would it then not be logical to replace the battery with capacitors that have their pole orientation just like that battery?
Quotethe only modification i did was remove the secondary batter install an sk3606 in series with one secondary wire the one that comes from the positive off the secondary cap and anode of the diode and fed it thru the sk3606 to positive where the run connection is
Does that mean that you connected the diode that goes to the battery inbetween the 2 capacitors?
I have attached 4 variants that i actually see now.
QuoteI noticed that ther is an ac component and it reads 13 volts on the ac scale so its still pulsed dc hitting the battery .
Please Gadgetmall could you make a voltage measurement across your caps?
I am quite certain that the charging effect is mostly due to the pulsed DC component, because i have measured 0.6 Volts on my caps.
That is not enough to (hot)charge the battery with current, so it has to be something else.
