One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
boku
 :o
can u point me to
10k and
1k 10% resistors
and 1n4937 diode?
cant find any
found the diode on http://www.reichelt.de
but the resistors not
jonnydavro
@Pirate.Thanks Bill.I saw this vid the other day by gatewurm.He makes some nice motors but when i saw this i thought of you as it was something you wanted to try a while back.He has two snake eggs,dualing in an "arena".It is quite amazing to see the interaction between the two magnets and the effect a high spin rate has on attraction.Jonny
http://www.youtube.com/watch?v=ClnFucGh3NM&feature=sub
@Boku.Hi.regarding coils.I use 26swg mag wire.I use two 250 gram spools and just wind them both onto a third,slightly larger empty spool.This coil works well and has a 1:1 transformer action which allows you to load the trigger side of the circuit but thats for later.The third coil i use is not one i wind but a 6v or 12v relay.I just put the coil from the relay in series with the resitors in the trigger circuit.
Regarding components.You may find it easier to buy a resitor pack which should have a wide selection of resitors and will probably work out cheaper for you and if you are going to have electronics as a hobby,it will be a good investment.You may also be able to get get transistor and variable resistor lucky bags from your local electronics shop and having a wide selection of components on hand will lessen the frustration of going back and forward to the shops.Happy experimenting.Jonny
Lakes
Quote from: jonnydavro on August 28, 2010, 06:57:32 AM
Also watch this vid by the daftman who makes it easy to build a working circuit and you can just use a diametrically magnetised magnet for your rotor.There are three vids in the series.
To get the high rpm's shown in the other levitating vids you referenced,you will need to have a well balanced shaft/rotor and then you should be able to replicate sucessfully.
Good luck.Jonny
http://www.youtube.com/watch?v=JJillO
Youtube says link is malformed....
gyulasun
Quote from: boku on August 31, 2010, 05:54:12 AM
:o
can u point me to
10k and
1k 10% resistors
and 1n4937 diode?
cant find any
Hello,
here is a list, the 1 kOhm is marked as 1K  Artikel-Nr. 405256 -62
http://www.order.conrad.com/cgi-perl/lshop.cgi?action=showrub&wkid=1265200006&ls=d&nc=&rubnum=e20.aa30.v97.bb94.p84&artnum=&file=&gesamt_zeilen=20&shop=
for the 10K:  Artikel-Nr. 405370 -62
These are 5% not 10% it is better perhaps.
jonnydavro
@Lakes and boku.Here is the correct link to thedaftmans step by step bedini build.Very useful for people just getting started with electronics as he makes it easy to get a working circuit by downloading his circuit diagram and you just place the parts on it.
I would go this route boku and i know you are not an electronics novice Lakes but the vids are worth a look anyway.Hope this helps.Jonny
http://www.youtube.com/watch?v=JJillOTsmrM
