mrd10
Exactly, there's very little in his first prototypes, He also mentions in that its like a turbine jet engine, when he removes the magnet, it winds down slowly, and this come to think about it, might be the magnetic field which is slowly dieing down, I know this may sound like bullshit, but something tells me that its easier than we think, and were barking up the wrong tree. Again I think we should experiment the way he has his first prototypes made, as these you can clearly see two rings and werent taped up like the later ones that he shows.
I think thats where we should start, keep it simple stupid...KISS    comes to mind, maybe he found this by accident, or it dawned upon him by researching other technologies....who knows for sure.
But its where Im going to head first off.
If you guys have made a start at his project and can make a jump by trying it, this would help me as well, since im stuck on another project, which im eager to finish.
Lets Help each other out.
Kindest Regards,
Mrd ;)
gn0stik
Quote from: supersam on October 03, 2006, 03:01:04 AM
tao,
i hate to ask it , but can a longitudinal transfer of electicity actually lets say run a motor? if so please explain how if it has no magnetic force, which would give it the mass to do so?
shuttinup, shuttinup.
sam
Dude, you need to do some research aside from this thread. Suggested reading topics, Heaviside Flow, JC Maxwell, Tesla, Edwin Gray, Floyd Sweet, Ed Leedskalning, TH Moray. That's a good start. By the time you read about edwin gray a bit you should have that question answered.
@Tao Nice work, I have read the first, but not the other two, yet.... It takes a while to assimilate this stuff into what we've already talked about.
Do you have a doc in which you've compiled all of the pertient info yet?
mrd10
Guys concentrate on these two, I snapped them in power dvd, the more you make sense of these images, the better will be to design.
From what i can tell look at the bailing wire, on the two rings of his first one, if you look at the bottom there seems to be two, half circumference
and on the top ring where he places the magnet on the coil, theres maybe 6 coils, which include the output.
Its the interaction between the way he has his coils setup, look how he has wound the bailing wire, it looks square or traingle configuration, pay particular attention to this. ive posted a few pics, if someone knows to enhance the images or enhance how the coils are done, i think were on the right track. I havent wound any coils yet so im not familiar with coil setup, i believe this small version is like the larger one he made, because if you look at the cutout of the larger one, it seems empty, so he has probably wound this same configuration around the cork like material.
Again concentrate on his first version, i think there is enough there to create it, if we can work out the way he has wound it, the copper winding ontop might be setup like a crystal radio setup, Ive been told you can make it with a coil.
bailing wire is the key and the way its wound, someone on this forum must be able to figure this out, ill try myself when it comes to it.
Cheers,
Mrd  ;D
giantkiller
Ponder this:
To start with you have two equally wound seperate coils. One is air core(#1) and one is iron core (#2). A desired freq, square wave is pumped into the air core and we get the kicks with the base freq. The magnetic field flies outward to the iron core coil #2 which gets saturated.  On the #2 you would get the DC saturation with an dampened ac on top, no? Now just play with the turns ratio and coil spacing for increasing the output.
The dampened ac on the output could be harvested back through a feedback loop across a tuned tank circuit to trigger an input action into the #1 air coil. This creates a closed loop Tesla coil, No?
dean_mcgowan
K.I.S.S
I have been trying to politely say this all along, I have watched and read most everything that has been reffered over the years and it all keeps pointing straight back to the same basic design. I honestly think tao is on the money and when Paul Lowrance reveals his design we are going to once again see the same thing again.
Its all just going to come down to resonance and materials used in a very simple configuration.
Life was not meant to be as complicated as those that need to feel superior wish to make it.
Cheers,
Dean
