Omnibus
Quote from: stgpcm on May 27, 2009, 08:57:40 PM
Unfortunately, I am not clever enough to devise a system capable of being such (although I have created one that works if you use Omnibus's method).
I am, however, clever enough to spot where Omnibus has made a mistake, and provide three different methods of calculating the same, correct answer - which also matches the experience of those who have attempted to build the machine - namely a counterclockwise acceleration where Omnibus's constructions predictions show a clockwise acceleration.
You are the one who's delusional. @eisenficker2000 spent even time to directly demonstrate where you're wrong. He didn't have to waste time to do that because your confusion is obvious. You don't want to learn but instead are wasting everyone's time with gibberish.
stgpcm
Quote from: Omnibus on May 27, 2009, 09:10:31 PM
you need to re-read what he said. As I requested, he demonstrated his method of calculation in the simple case, which allowed me to confirm it contained the error I suspected.
He doesn't read this thread, because of you.
Omnibus
Quote from: stgpcm on May 27, 2009, 09:19:26 PM
Are you his speaker to know why he does or doesn't read this thread?
What error? You are the one who doesn't understand the essence of the problem. There's no error in @eisenficker2000's analysis.
LarryC
Okay, Omnibus and stgpcm arguments are starting to seem very questionable. Check their recent post timings. They seem to be the same person with different sides of a distracting  arguments.
Check reply 25 at  http://www.overunity.com/index.php?topic=7472.msg183041#msg183041. Does anyone else see the resemblance?
Sorry, but these two seem to be very good at trying to mislead the thread from its goal.
Regards, Larry
Omnibus
Quote from: LarryC on May 27, 2009, 11:19:48 PM
Regards, Larry
Distracting arguments? Distracting from what, from the role of the centrifugal forces? That has been commented already and your misunderstanding it isn't a basis to consider it the worthy topic of discussion. What you're doing is distracting because it's bringing in nonsense in the discussion.
