MylowHJ Replication - Discussion
Started by wattsup, April 04, 2009, 08:49:58 PM
Omega_0
As you guys already know:
Rotor mag outer spacing = 9 mm (average)
Rotor mag inner spacing = 6 mm (average)
Stator mag spacing(along width) = 7.12 mm
Stator mag spacing(pole to pole) = 2.35 mm
Stator height = ?
AnandAadhar
Mylow responds to honest posting at YouTube:
Me (see also my previous posting):
The stator might have to trigger that effect from a high voltage wire outside...we don't know, we are flabbergasted. Mylow tells his brother: you tell it, you are the expert, but there are no experts in magnetic motors. Johnson is dead and the rest is either nerd, too theoretical, or not to replicate either, like with Perendev and the miraculous 'screw' motor. What can we do but keep trying and thank Mylow for taking the trouble to show us? That is what I do....
magneticmotor1:
play with the magnets under the stator and you will see what i mean.
thats going to be my next project.
yes your right it is but with larger magnet and more powerfull colbolt type it my run for a longer time.
i think it will slow down and keep that speed.
Me again:
A zinc plate works also. I have a selfsustained movement with heavier stators, but only as yet when I hold two stators extra by hand. I use 4 above a plate with six groups of five magnet bar assemblies. I have to use an uneven number though to use two stator sets alternatingly. All I have is the very small magnets. I assemble everything, stators, rotors like lego with them. Gives a lot of freedom to try. I am close to the selfstarter and will post my movie upon success. But not as long as I fail.
This is my position now. Holding by hand two extra stators to a double paired assembly with six groups of five bars on a 75 cm zinc covered plate of non-magnetic material, makes selfsustained movement possible in my case. Within a couple of days I will be regrouping the rotor magnets for seven groups, and maybe then it will work of a fixed stator assembly too. I have good hopes but no definitive experimental proof of OU by HJ-Mylow replication yet. As Mylow says, you have to believe in it and be ingenius, because each other type of material one uses demands a different configuration. I hope to post  my series of videos about this project soon (i keep a video log of the proccess)
AA
I changed my mind and have loaded a preliminary replication movie of what I am doing. Mylow specifically asked for it. so here it is:
http://www.youtube.com/watch?v=mAhe1nX0HLM
Anand Aadhar free energy research pages: http://theorderoftime.com/science/free_energy/index.html
Omega_0
RunningBare
Quote from: AnandAadhar on May 15, 2009, 03:44:33 AM
No he does NOT, I put honest criticism in comments, none of them have ever shown, he is very very selective in what he choose to allow, 99% support for him, I say 99% because sometimes he thinks I better let criticism show or it's going to look bad with 100% support only.
