Please, Please, look at this video!
Started by Butch LaFonte, April 08, 2009, 11:57:53 PM
ramset
Ergo
Period, is a very big word
This trigate with the heavy iron plate centrifugal force Etc...[
http://www.youtube.com/watch?v=ChGB3delzoA&eurl=http%3A%2F%2Fwww.youtube.com%2Fmy_videos_edit2&feature=player_embedded
Chet
My crystal ball is in the shop right now [time will tell]
Thanks Grandma
Low-Q
Quote from: ramset on April 11, 2009, 10:19:27 AM
Q
So what is happening here?
Chet
A heavy wheel which is slowing down. That is what is happening. Look at the speed at the very beginning, and jump directly to the end of the video. It clearly slows down. at least 10 -15% slower after one minute.
Vidar
tournamentdan
I saw the video that you did with the balance affect with the 25 pound pipe. I stopped there and did not watch any other because your theory that the two magnets are stronger together than apart is wrong. I am sorry to say but the reason that they seem stronger is because the magnetic poles for the rectangle magnets are in the center. The farther away from the pole the weaker the attraction.
I'll see your theory, and raise you mine!!!
Low-Q
Quote from: Tempest on April 11, 2009, 11:00:09 AM
OK Low Q
What molecular, atomic, quantum or any other mechanism holds the radiation in, in a cobalt magnet?
Or is it consumed to create the magnetic field?
Can you alter the effect by external force?
Do you know what makes a magnet a magnet?
Do you know the precise mechanism that products the magnetic fields or are you just repeating what you learned in school?
Please enlighten with your vast knowledge in this area.
The radioactive cobalt isotop 60 isn't used in magnets, and does not exist in nature due to the very short half life of only 5 -6 years or so. It is manufactured synthetic for industrial purpose - not for magnets. It is the non radioactive and a stable isotop of cobalt you use in magnetic alloys.
A magnet is a potential charge of current, like as any other potential charges found as voltage in electric capacitors, or as mass upon a table.
The atoms in a magnet are oriented in a way that makes the electrons spin more or less in the same direction - therfor the magnetic field. As long these atoms stays in the same order, no change in potential energy is carried out, so no work can be done.
You can however temporary change the magnetic flux and direction by introducing another magnetic material, but that change will follow the material and eachother as it is passing by, so no net change in the forces are present in a closed loop.
Vidar
Ergo
Quote from: ramset on April 11, 2009, 11:15:45 AM
Ergo, Period, is a very big word
In this case it is justified.
Time will be telling forever when it comes to tri-gates.
Just have another look at the poor motion in the video.
There is no torque what-so-ever to speak of. It's barely passing the gates.
Slightest shaft load from a connected generator will stop it.
Hell yeah....even the lite drag from a unloaded generator will immediately stop it.
